- 30 Jun 2006
- Cardiff
What kind of temps do you get?Mine boots and benchmarks with a PBO of -40, scaler of 10x and +200Mhz but stressing is certainly another story
Same, (haven't messed with scaler though). Although I had a couple of big hitches in Helldivers last night so I might go -38 or something. No problems otherwise.Mine boots and benchmarks with a PBO of -40, scaler of 10x and +200Mhz but stressing is certainly another story
I don't think temps was the issue that -40 on PBO fails on OCCT & Prime95, I'm around high 70s low 80s while using those.What kind of temps do you get?
Maybe you will notice when you up your resolution or play more demanding games.Upgrade from 7800X3D all done - of course I can't tell any difference at all lol
Made sense to upgrade though after nabbing the 9800 at a good price and with used values on the 7800 so strong.
what's your cpu overlcock settings?The latest ASUS Bios update (AGESA 1.2.0.2b) fixed the latency issue with Ryzen 9800X3D.
same with mine pre-delidding. but fails when running OCCT at -40, so had to drop to -35 before fully stable. Temps were in the low 80s.Same, (haven't messed with scaler though). Although I had a couple of big hitches in Helldivers last night so I might go -38 or something. No problems otherwise.
Exactly the same here - failed OCCT, got it to last an hour at -35, but instantly crashes doing a multiple AVX benchmark, dropping it to -30 solves that. But realisically I don't think I'll ever do anything as demanding as that, and it was fine with gaming and C23 at -40. So I'll probably stick with that as the temps were amazing.same with mine pre-delidding. but fails when running OCCT at -40, so had to drop to -35 before fully stable. Temps were in the low 80s.
Need to retest what i can do now.. when i have the time
I used the overclocking guide below. I set my CPU to -30 and +20 where it's stable at 5.7GHz.what's your cpu overlcock settings?
Two possible reasons, you either hit the power limit (more likely, I believe its 168/170W with max power limits) or you hit the temperature limit, of 95c (less likely).My 9800x3d did something strange tonight as I never seen it before. So tonight I ran a cb23 test and it did 5.4ghz all core while running it. Before in the past when I ran it it dropped to like 5.1 ghz all core when under multi core testing. Does anyone know the reason for this?
I think I set my pbo limit to motherboard last night. I just never seen it do 5.4 GHz all core when doing something like c,b23 or occt. What is your power draw normally in occt? Mine says 150w is this right?Two possible reasons, you either hit the power limit (more likely, I believe its 168/170W with max power limits) or you hit the temperature limit, of 95c (less likely).
What app were you using to monitor clocks? HWINFO64 effective clock monitoring is not always accurate I've found.I think I set my pbo limit to motherboard last night. I just never seen it do 5.4 GHz all core when doing something like c,b23 or occt. What is your power draw normally in occt? Mine says 150w is this right?
Do you have the product code for that set please?Testing G.Skill Royal Neo 6400c30 @ 6400c26
ah my msi tomahawk doesn't have the eclk option, I tried the curve shaper settings but that seemed to make it perform worse at cinebench than using curve optimiser -30.I used the overclocking guide below. I set my CPU to -30 and +20 where it's stable at 5.7GHz.
