For comprehensive and 100 excess?I am surprised yours is that expensive, I think mine was about £150 less. It's a 3 door hatch but I had assumed they'd be the same price, obviously not.
Yup I bet my particular clubman has potentially more to go wrong than your 3dr.Yes.
I assume the Clubman isn't treated the same as the hatch.
Although, what is the mileage on yours?
Other than vanos (on non-s models) and throttle body I'm not sure what adaptions can be reset (and wouldn't have thought either of those should affect stop start)
Had a low pressure warning for one of the rears tyres on the Countryman.
Think it was just low, but took a closer look at all the tyres - both rears were the original tyres (that were on the car from new (2017 date code Bridgestone Turanza T001)), and both have significant cracking within the tread blocks (despite still having 2-3mm left).
Yep unfortunately - but given how I was treated with the fuel leak a week after buying it, I'm not surprised.And this was on an approved used car? I would have expected them to be changed upon inspection by the dealer.
Mine is on my build sheet C2C Pure Burgundy.Anyone know where the paint code sticker is on a 2017 Countryman?
Tried all the door jambs, everywhere I can see under the bonnet, and no luck.
After some touch up paint and want the correct code as there seem to be a couple of variants of Melting Silver
Haha not on greatest terms with the Dealer, so will give that one a missIf you don't have it, ring the dealer with your VIN and they'll look yours up.
Not serious enough for a S.M.A.R.T repair? Mine was scuffed/scratched in 7 places, he's fixed them all...After some touch up paint and want the correct code as there seem to be a couple of variants of Melting Silver
Nope just normal stone chips on the bonnet that will no doubt happen again as soon as it's repainted.Not serious enough for a S.M.A.R.T repair? Mine was scuffed/scratched in 7 places, he's fixed them all...
Should cause no harm and Wynn's stuff is normally pretty goodQuick Question:
I have a Mini Cooper Diesel 2010.
The Diesel Partiulate Filter warning light comes on just fater start up and then goes off, my brother reccomends putting this into the tank. He said it cured the same issue in his car (not a Mini)
https://www.halfords.com/motoring/e...-particulate-filter-cleaner-325ml-325222.html
Just wanted to double checkthat this is a good idea?
