I have a 5800x currently, do you think its worth it to upgrade to a 9800X3D or a 9900X3D (when it releases) if im mainly going to be playing 1440p and sometimes 4k?
I hear some people say it wont make any difference at higher resolutions, but then others say it makes a big difference for the 1% lows and its just a bit more stable
Depends what GPU you're pairing it with.
If it's something like a 4080/4090 or 7900xt/x then yes you will see a difference in 1% low/avg/max
If it's a slower GPU, you'll probably only see a difference in the 1% lows
