Its in the ZF 8HP gearbox.
Ok so two different things. I think my auto start stop may have been coded out or doesn't work as I have the button and the light on the dash on the 120d e82 but iv never used it, it's always been like that.BMWs have had efficiency dynamics for years. It doesn’t, by default, mean it’s a mild hybrid.
You can code out stop start by default.
It sounds like you’re talking about the driving mode, rather than the Efficiency Dynamics model variant of some 2010+ BMWs. From memory these were just lower tuned versions of the normal car.
Looking on Google the proper mild hybrid then is the 48 volt starter generator mild hybrid system.
For example provides 11 horse power of electric boost whilst accelerating .
What about the actual numbers being advertised. E.g 420i avg 42.2mpg. / 420d 57mpg
I'd like to try petrol if it's going to be better than diesel.. as most of you may know my last 4 cars have been diesel. sometimes reliable, sometimes not. I don't want a gas guzzler through town but I also do dual carrageway and some motorway journeys but if the numbers are not trustworthy and the mpg is actually in the late 30s on the petrol then it may sway me back to diesel.
I used to get 55 plus in a 320d on a run, and I think you’d have no problem getting 42-45 in a petrol 3/420i on a run, assuming a 2016 ish car onwards.
My 340i manual, which sits at >2.5k revs on motorway will do 36 on a run.
Same as the veterinary industry, Or possibly EVERY industry that has a insurance backing.Rates are designed to rip off insurance companies.
I get about 52-53 realistically at the moment.
It's just weighing up really now if I want to go petrol or diesel, the other thing is if I go for the 4 series or 3 series. a lot of reviews say even though the 4 series is bit more expensive it seems worth it over a 3 series.
Or it could be the other way around and it's not worth getting a 4 series when the 3 series is just as good and costs less.
I was looking at the 420 grand coupe
I don’t know what your driving circumstances are, but petrols are quite good for fuel economy these days.
The only challenge for me with a 20i is that it felt less torquey than the diesel I used to own (had a 320i loan car for a week).
I used to average 53 MPG in the 320d and averaged 37 in the 320i with no changes to my driving habits. In fact it was used for longer journeys.
3 vs 4 is a personal choice. I think the 4 M Sport comes with the pro nav as standard which is a nice bonus.
As @tamzzy said - hatchback boot is great. Worth noting that folding rear seats, at least on the 3 series, is an optional extra so if you’ve need a sizeable boot, a 4 GC may be best.
Running the engine at idle won't charge it much, if at all. Can you plug in a trickle charger?Here's a question for you lot,
I've got to go overseas for a month, my G82 M4 - will the battery deplete in that time? is it worth getting someone to run the engine for 10-20mins or so 2 weeks in?
Or will it be just fine?
It'll be fine.Here's a question for you lot,
Sounds like the perfect use case for a hybridThis is what worries me about switching to petrol, will it drink lots of fuel quickly darting though start stop traffic every 5-6 meters. Although saying that it has to be better than diesel
Sounds like the perfect use case for a hybrid![]()
That should be in the range that a diesel makes economical senseI think my milage looking at past mot for last year is around 13500 miles
