But runways only work in one direction, even in good weather apparently.You are aware what an emergency landing is right?
"The plane initially tried to land on the airport's Runway 1, but the pilot was told to instead land on Runway 19"You are aware what an emergency landing is right?
Why did they land in the direction of the solid wall? A full 150m from end of runway? A runway that is 3k long?
Not even sure what that means. It's one runway labelled 01 and 19 at either end.But runways only work in one direction, even in good weather apparently.
And why do you think that was?"The plane initially tried to land on the airport's Runway 1, but the pilot was told to instead land on Runway 19"
It's the same runway but opposite ends - one end with a concrete block 150m from the end, the other without.
You tell me..but it seems quite a simple fix to the concrete block problem Vs. making runway a square 10km with zero obstacles.And why do you think that was?
"Tower, we've a double engine flameout, bird strike, request immediate landing"You tell me..but it seems quite a simple fix to the concrete block problem Vs. making runway a square 10km with zero obstacles.
Are you trolling now? I'm happy to admit I've read this wrong, but from what I read this is exactly what happened. They aimed for runway 01 (I.e. flying over the concrete) and were told to abort and go to runway 19 (the runway that ended in the concrete block)."Tower, we've a double engine flameout, bird strike, request immediate landing"
"Nah go around mate, our runway isn't safe"
3 of your 4 posts in this thread are about me. And the same with the honey thread. You aren't even engaging in the topic, you are just weirdly following me around and providing some voiceover lol??I dunno what's going on with you dude but this fall from grace you're going through lately isn't nice to watch.
Whatever it is that's causing this, I hope you resolve it soon <3
Keep up. It's labelled 01 one end, 19 the other end.There's only one runway.
It's still one runway. Doesn't matter if I put 4 on my wrist and 4765987354 at my shoulder, it's still one arm.
cope. I hadn't made out it was more than one runway.3 of your 4 posts in this thread are about me. And the same with the honey thread. You aren't even engaging in the topic, you are just weirdly following me around and providing some voiceover lol??
Runway 01 and runway 19 is the same runway - it's labelled differently at each endYou wot m8? At no point in that do you say they were told to come in at a different direction on the same runway. You refer to runway 01 and runway 19.
