At least you fixed it, most people seem to just stand by the car waiting for the recovery truck these days.
If you get a newer car you could do that too.![]()
Valeo were the number 1 choice back in the day - not sure what happened to their rep. I fitted Valeo's on my E43 and they are great.Annoyingly the bosch aero blades were out of stock, so i have stuck valeo on, have had them befire and they were terrible.
But anything is better than a split blade that goes over the eyeline!
Will change them for decent ones in the summer.
Let us know what it's like, I've been eyeing one up for my car.Removed the cod piece:
Added an integrated cam, taps into the rain sensor wiring so all plug and play, and most importantly, tidy:
Today I finally changed my wipers to see if I can cure a really annoying smear right in my eyeline.
You can put the same battery from a Sport 300 570a into a Trophy with a DESS its plug n play (Renault tell you no but it works just fine no more DESS battery problems then!).Just changed the poxy lawn mower battery in my Megane with a fresh one. I'm not sure why Renault decided to do what they did but 10 minutes later and the battery no longer dies after 2 minutes of the ignition being on.
I hate Bosch blades, I think they're rubbish. They don't last 5 minutes before they're juddering and smearing all over the show.
I genuinely prefer the cheap knockoffs you can get on eBay.
