Not worth it at that price. There's still 6750xts going for a smidge more. The price increase is a significant 20% for the same exact thing.Intel B580 LE cards back in stock, for £300(!!), shipping for the 7th. I assume that backlog for that particular card is cleared now then?
£250 is where it needs to be, £300 is a no. Especially looking at that cpu overhead.
Further testing on the CPU overhead issue
Turns out Arc cards performance falls of a cliff on older CPU'sTell us how it performs, because my B580 did not behave as I expected.
Just like only some of the CPU's are gonna fail...Only in some games. It's not consistent.
... at 1080p where it's likely CPU bound.. you'll notice in your video that the RTX card performance scaled with better processors - not just an intel issue, just exacerbated at 1080p... good job there's plenty of data at 1440pImo the B580 is DOA, I could never recommend ARC to anyone with this serious of an issue.
33% drop in Spiderman going from 9800x3d to 7600? Disgraceful.
It's a testament to the work NVIDIA and AMD have put into their drivers when you see their cards completely unfazed as the CPU gets slower. Rock solid performance from the 4060, even with a 5600. The B580 gets obliterated.
HUB is actually going to re-review the B580 with a 5600 CPU, which should hopefully put pressure on Intel.
On every CPU. I use 7600x and b580 falls of a cliff while 4060ti and rx7700 performs very wellTurns out Arc cards performance falls of a cliff on older CPU's
On x-planeOn every CPU. I use 7600x and b580 falls of a cliff while 4060ti and rx7700 performs very well
The bitter truth hurtsOn x-plane![]()
Not on every CPU, otherwise we wouldn't be seeing the benchmarks of it beating the 4060 in most cases, and the much more expensive 4060ti in a few cases (just not your beloved x-plane apparentlyOn every CPU. I use 7600x and b580 falls of a cliff while 4060ti and rx7700 performs very well
)Run 1440p and problems solved? It smashes the likes of the 4060 at higher resolutions even when not vram limited.
