- 13 Jan 2004
- South East
What codec and frame rate do you set in VD settings?
I tried to play HL:Alyx yesterday using Virtual Desktop, with my PC on in another room. I kept getting stutters, and if I turned my head quickly it's like the image was delayed and I just saw lots of black. Basically it was unplayable.
I only have a basic Virgin Media WiFi setup with the Super Hub 4 (I think, which I believe is a WiFi 5 router). Could this be the issue? Would WiFi 6 make that much difference? Is it worth me asking VM for a Super Hub 5 as that is WiFi 6. They don't have anything that is 6E currently and I want to avoid spending money.
I don't have access to all my settings to share right now but just curious if anyone else has experienced this before and knows a simple solution?
Flight sim still looks crap though.
Grabbing a tplink wifi 6e router was by FAR the best thing ive done so far for my quest 3 pcvr setup. in virtual desktop you can just crank the bitrate all the way up and havent had even a single stutter so far and thats using my headset 2 rooms away from the main pc and router. Game changer.Some games look pretty bad over wireless unless you can get a 6E router and really crank the bitrate up.
It's normally games with lots of foliage or dark muddy colours. Skyrim VR is a particular case.
Does this actually sharpen up and improve media playback like SkyBox Vr or Bigscreen Beta? ThanksI've been playing around with the quest game optimizer. Quite a powerful tool for 10 quid. Some profiles aren't quite refined e.g. contractors exfil, I get frame drops on bigger maps but fine on smaller ones. Resolution boost is welcomed.
Demeo is incredibly sharp and it's crazy that these developers can't offer patches to tweak resolution for quest 3.
I went back to trying vader immortal - wow, the ridiculous blurry text on the load in screen is gone and runs smooth with the hd+ profile.
I wonder if they will follow the same console path - offer performance and quality modes going into the latter half of quest 3 life cycle and quest 4.
This puzzles me too tbh. I know how easy this is to do - 1. do a check for what headset it is (1 line of code) - 2. perform a resolution increase if it's a Q3 (1 line of code). I try to avoid games/apps that aren't optimized for Q3.(snip)
(snip)
yes, yes you do..I either play golf with the guys, maybe some Demeo now I've installed that, I had a battery pack, the only other stuff I play I'm hardwired to my PC, but do I reaaaaaly need sideloaded stuff?
Hey guys, I've just picked up my quest 3... can anyone recommend any essential accessories etc?
Quest 3 accessories thread
You can now pre order the meta Quest 3 (October 10 Official release date) and also Meta are doing facial interfaces and different colour straps and new elite straps AMVR Quest 3 Stuff (Controller grips and protectors , more added soon) https://www.amvrshop.com/collections/quest-3...forums.overclockers.co.uk
