does the pc work with your old cpu? if it does then you can check the bios version in biosHow can I check if the bios upgrade is done correctly? And would it be worth just taking it to a tech guy to be certain
no it didn'tthis board have 5800x support from day 1
the board was released with bios 30 (2019)
only in bios 3A was the 5800x supported (2021)
