Added support for DLSS 4 with Multi Frame Generation for GeForce RTX 50 Series graphics cards, which boosts FPS by using AI to generate up to three times per traditionally rendered frame
The "DLSS is worse than native" crowd are suddenly silent![]()
I'll check back later
thanks for this
The new DLSS FG file is massive difference, I dropped it into Horizon Forbidden West and went from like 140-150 to 170-180
Since its just using the CNN model still it looks identical, just more FPS and less vram from FGHow does it look?
