Hostile_18
Hostile_18
OP
So far no one has reported anything terrible, that just came from reviewers. Fingers crossed.
Cause there weren't any on shelves to buy?So far no one has reported anything terrible, that just came from reviewers. Fingers crossed.
If you always use headphones you'll be fine, otherwise fans do ramp up here and there and coilwhine/buzzing is covered by fan noise for the most part.I have been getting @Personality+ to do extensive tests with his card. Sure he'll bring us his official verdict of the FE in due course![]()
Can we get audio?If you always use headphones you'll be fine, otherwise fans do ramp up here and there and coilwhine/buzzing is covered by fan noise for the most part.
Everyone has different tolerance levels... I'd prefer to have a dual bios 5090 with a silent mode personally even if it did have whine, at least then fans aren't in the mix as much.
Not as bad as some of the reviewer youtube videos though....
Let me add (stock settings)
I couldn't really capture it with the case closed on my phone, but could hear it...Can we get audio?
the fans for the most part overpower it, when it's present.
Sorry to hear that and glad it doesn't bother you. Last gen the Zotacs with the Giga were excellent for not having coil whine. Wonder why the zotacs have coil whine now. And likewise the Msi suprim X's were notorious for coil whine like the strix bu this time round it doesn't have any. Well at least not that sample in that review.Managed to get one of the Zotac 5080 Solid OCs which arrived today, it certainly has some coil whine but not intollerable to me.
My case is a Fractal North XL mesh with the three stock Fractal fans in the front, Arctic III 360 up top and one additional 140mm Arctic P14 at the back so not a silent build by any means but it is virtually silent when idle and even under load the fans and pump don't seem to really work too hard.
Appears to be worse when the FPS is very high - running Timespy at 1440p when it hits 250+ FPS it is auidble from about 50cm away with my case up on my desk, outside of those scenarioes though it seems to be fine to me though.
For my uses it is fine, and certainly with a pair of closed back headphones for gaming use I cannot hear it at all.
Is 1 lots of coil whine or 10 is the most?Coil whine reports for 5080 seem all over the place. Lowest Guru3d ranking is for the FE (5/10), which is absolutely not consistent with their 5090 reviews. Both ASUS and MSI at 8/10.
Made a couple of short clips under different scenarios, the Timespy is by far the worst one as the pitch seems to go up with the FPS.can we get an audio sample?
Zotacs own OC software should turn it off permanently-cant remember the name of it, then uninstall it if you don't need it.(and I need to figure out how to disable the silly RGB lighting too!).
Coil whine
The presence of coil squeal in any GeForce RTX 5000 graphics card can vary, depending on the degree of the issue. It becomes audible when reaching high framerates, but typically remains at a manageable level. Within an enclosed case, this sound is likely to blend into the background noise. In our experience with this specific card, the coil squeal has been very noticeable to us. This product RTX 5080 will make coil whine, rated 8 out of 10.
How's the upgrade, that's quite a jump!5080 FE owner here. Just got the card a few hours ago and while there is a bit of coil whine, it's nowhere near as noticeable as I was expected - especially compared to my old Zotac 1070 which was terrible for coil whine.
Plus, it only seems to happen during loading screens when the frame rate ramps up into the thousands.
Fans are not too loud, with my previous Gigabyte 3080 Gaming OC I had to make my own fan curve as it was unbearably loud but I don't feel I need that with the 5080.
