Caporegime
- 7 Apr 2008
- Lorville - Hurston
They voted for himTrumps tariffs started today and GPU 5090/5080 prices increased in the us lmao
There are 2 similar cards, the Ventus 3X OC which is selling for the same price as the FE it has 4 heat pipes, and is the one I got. Then you have the Ventus 3X OC Plus which is the one they are complaining about on reddit, it is more expensive, and has 6 heat pipes. Both of the cards are power limit locked and I agree the plus should at least go to +6% like the FE does. You can get to 3.1- 3.2 GHz without hitting the power limit though so for most people the increased power limit is not really needed on the 5080.Seen a few people raging on reddit today and saying they are sending their cards back because the Ventus is power locked. Essentially complaining they paid upto £300 more than an FE which can raise its power limit to 110%, so they paid more for less.
5080s do look like good overclockers though
Make sure you are using the latest version (4.6.6 Beta 5 Build 16555). In settings compatibility properties enable Hardware control and monitoring, Low level IO, Low level hardware, Restore after suspended, Unlock voltage monitoring.Hi. How do you get MSI afterburn to show the gpu voltage and clock speeds?
Mine only has option to show the gpu temperature and usage
I picked up the MSI Inspire 3X which has 5 heat pipes I believe. You can increase the Power Limit to 105% on the card.There are 2 similar cards, the Ventus 3X OC which is selling for the same price as the FE it has 4 heat pipes, and is the one I got. Then you have the Ventus 3X OC Plus which is the one they are complaining about on reddit, it is more expensive, and has 6 heat pipes. Both of the cards are power limit locked and I agree the plus should at least go to +6% like the FE does. You can get to 3.1- 3.2 GHz without hitting the power limit though so for most people the increased power limit is not really needed on the 5080.
Interesting they say the 5080 doesn't boot with 2 x 8 pins either which would be 300 watts, and if they had allowed the PCIe slot to provide power that would be 375 watts, and been enough.Saw an interesting article today showing the 5090 won't pull power from the PCIE socket even if it can't get its 600w from the 12 pin cable and also won't exceed the load rating on the cables connected to the adapter.
This basically just means if you use a 3x8 pin adapter or only connected 3 cables to a 4 pin adapter, the 5090 will limit its power and run a bit slower as a result - typically 5-10% depending on the game.
If you only use 2x8 pins to connect to the adapter then it limits the card to 300w and then the 5090 runs slower than the 4090 in certain games.
So if you have a 5090 and want to get the full performance of the card, its best to use the adapter that came with the card and connect 4 x 8 pin cables to it. If you connect less than 4 then you can lose 5-25% performance
RTX 5000 an zu wenig Kabeln: RTX 5090 geht mit 3×8 Pin PCIe, RTX 5080 aber nicht mit 2×8
Kann die GeForce RTX 5090 an nur dreimal 8 Pin PCI Express betrieben werden? Ja, sie kann und operiert dann mit weniger TDP.www.computerbase.de
I use the x2 8 pin on the 4090 and that goes over 500w with unlocked power limits. It’s a cable mod extension cable. That’s strange.Interesting they say the 5080 doesn't boot with 2 x 8 pins either which would be 300 watts, and if they had allowed the PCIe slot to provide power that would be 375 watts, and been enough.
I wonder if they are going to try and power limit the 5070 ti somehow so that it doesn't get too close to the 5080.
Complete BS. Used 4090s were already going for £1500 upwards second hand before the 5080 price was even announced.Blame those paying up to £1700 for the 5080 if those were 1k then 4090s would be around £1200, the 4090 is a faster card with more VRAM so it’s worth more.
If you're spending that kind of money then a 4090 genuinely makes significantly more sense.
For £100-200 more you get a card with 24GB of VRAM and is quicker in everything.
Its a long term strategy to get manufacturing done in the US. It will sting at first but will probably end up working.They voted for him
If that's the intention i can think of better ways of doing it, like through adding VAT to certain products and giving grants to companies if they manufacture wafers in your country.I guess the intention is to encourage fabs to setup in the US and to give an advantage to companies like Intel. Time will tell if it works though....
Looking at the 600w cards, first issue that would happen would be burned cards.
That isnt a suprise due to once one push things to the extreme things can easily break for many reasons.
a new issue just happen
Some GeForce RTX 5090D/5090 users report issues following first driver update - VideoCardz.com
Multiple GeForce RTX 5090 cards said to have stopped working after driver update For now, reports mainly from Asia. Users are reporting issues withvideocardz.com
So the 5090s are not compatible with PCIE5 now, which is the reason for them getting bricked !
https://www.guru3d.com/story/troubleshooting-rtx-5090-black-screen-failures-switch-to-pcie-gen-40/
Isn't Ventus generally their cheap model? Which means worse components and so it should always be cheaper than FE (but MSI claim they can't lower prices as Nvidia overcharges them). No wonder they put locks on it, for OC they offer more expensive models and this one likely simply can't handle it fully stable.There are 2 similar cards, the Ventus 3X OC which is selling for the same price as the FE it has 4 heat pipes, and is the one I got. Then you have the Ventus 3X OC Plus which is the one they are complaining about on reddit, it is more expensive, and has 6 heat pipes. Both of the cards are power limit locked and I agree the plus should at least go to +6% like the FE does. You can get to 3.1- 3.2 GHz without hitting the power limit though so for most people the increased power limit is not really needed on the 5080.
Another evidence this whole launch has been really rushed and not well tested beforehand.So the 5090s are not compatible with PCIE5 now, which is the reason for them getting bricked !
no it won't because the US cannot compete with China's low manufacturing costs due to lower wages and land costs (which is the reason all the tech companies make their goods there in the first place), so inevitably prices will go up.Its a long term strategy to get manufacturing done in the US. It will sting at first but will probably end up working.
