NVIDIA RTX 50 SERIES - Technical/General Discussion
Seen a few people raging on reddit today and saying they are sending their cards back because the Ventus is power locked. Essentially complaining they paid upto £300 more than an FE which can raise its power limit to 110%, so they paid more for less.
5080s do look like good overclockers though
There are 2 similar cards, the Ventus 3X OC which is selling for the same price as the FE it has 4 heat pipes, and is the one I got. Then you have the Ventus 3X OC Plus which is the one they are complaining about on reddit, it is more expensive, and has 6 heat pipes. Both of the cards are power limit locked and I agree the plus should at least go to +6% like the FE does. You can get to 3.1- 3.2 GHz without hitting the power limit though so for most people the increased power limit is not really needed on the 5080.
Hi. How do you get MSI afterburn to show the gpu voltage and clock speeds?
Mine only has option to show the gpu temperature and usage
Make sure you are using the latest version (4.6.6 Beta 5 Build 16555). In settings compatibility properties enable Hardware control and monitoring, Low level IO, Low level hardware, Restore after suspended, Unlock voltage monitoring.
Do not enable Unlock voltage control because it has a bug in the Nvidia driver at the moment with voltage control on the 5000 series, and you don't need it anyway because you control the voltage with curves.
Saw an interesting article today showing the 5090 won't pull power from the PCIE socket even if it can't get its 600w from the 12 pin cable and also won't exceed the load rating on the cables connected to the adapter.
This basically just means if you use a 3x8 pin adapter or only connected 3 cables to a 4 pin adapter, the 5090 will limit its power and run a bit slower as a result - typically 5-10% depending on the game.
If you only use 2x8 pins to connect to the adapter then it limits the card to 300w and then the 5090 runs slower than the 4090 in certain games.
So if you have a 5090 and want to get the full performance of the card, its best to use the adapter that came with the card and connect 4 x 8 pin cables to it. If you connect less than 4 then you can lose 5-25% performance
I picked up the MSI Inspire 3X which has 5 heat pipes I believe. You can increase the Power Limit to 105% on the card.
I've hit 3Ghz easy on this card too, makes a noticeable difference in performance which is nice. The 5080's seem to clock excellently.
Interesting they say the 5080 doesn't boot with 2 x 8 pins either which would be 300 watts, and if they had allowed the PCIe slot to provide power that would be 375 watts, and been enough.
I wonder if they are going to try and power limit the 5070 ti somehow so that it doesn't get too close to the 5080.
I use the x2 8 pin on the 4090 and that goes over 500w with unlocked power limits. It’s a cable mod extension cable. That’s strange.
Blame those paying up to £1700 for the 5080 if those were 1k then 4090s would be around £1200, the 4090 is a faster card with more VRAM so it’s worth more.
Complete BS. Used 4090s were already going for £1500 upwards second hand before the 5080 price was even announced.
If you're spending that kind of money then a 4090 genuinely makes significantly more sense.
For £100-200 more you get a card with 24GB of VRAM and is quicker in everything.
For me, at the price I got my 5080 Vs what I could have gotten a 4090 with warranty for, I saved £500, and in the games I play the "quicker"ness of a 4090 is in single digits.
When the reviews first dropped and all the 4090's were gone I was kicking myself, but actually I think I ended up with the better choice.
Trumps tariffs started today and GPU 5090/5080 prices increased in the us lmao
That's OK. They'll just have to buy American GPUs made in the good 'ol USA!
I guess the intention, as other have stated, is to encourage foreign companies to setup fabs to setup in the US and to give an advantage to US companies like Intel. Time will tell if it works though....
I guess the intention is to encourage fabs to setup in the US and to give an advantage to companies like Intel. Time will tell if it works though....
If that's the intention i can think of better ways of doing it, like through adding VAT to certain products and giving grants to companies if they manufacture wafers in your country.
Looking at the 600w cards, first issue that would happen would be burned cards.
That isnt a suprise due to once one push things to the extreme things can easily break for many reasons.
a new issue just happen
There is a few different issues happening
* Some combination of rtx5000 card and motherboard are refusing to operate at PCIE 5 and only work on PCIE 4.
* Some combination of rtx5000 cards and motherboard don't recognise eachother and the bios and windows can't detect the GPU even when using PCIE 4 or 3.
* Some users report black screens on latest driver with RTX5000 cards, cause is unknown and seems random
Isn't Ventus generally their cheap model? Which means worse components and so it should always be cheaper than FE (but MSI claim they can't lower prices as Nvidia overcharges them). No wonder they put locks on it, for OC they offer more expensive models and this one likely simply can't handle it fully stable.
Its a long term strategy to get manufacturing done in the US. It will sting at first but will probably end up working.
no it won't because the US cannot compete with China's low manufacturing costs due to lower wages and land costs (which is the reason all the tech companies make their goods there in the first place), so inevitably prices will go up.
