Caporegime
- 7 Apr 2008
- Lorville - Hurston
GeForce RTX 5090 reportedly works with 3x 8-Pin power adapters, but stays limited to 450W - VideoCardz.com https://search.app/pBgAutbjKY4bhbAh8
That was due to demand from miners though, why so much now?The RTX3090 says hello.
The FE should probably be your top choice if space is the issue. It cools very well and is more compact than anything else I have seen. The MSI Ventus 3X OC and OC plus are 2 and a half slots so also could fit if they are not too long. (Card Dimension (mm) 303 x 121 x 49 mm).Hi folks,
I'm looking at potentially purchasing a 5080 card, my space is limited in my case to about 3.5 slots, but is there a certain card/brand people would recommend?
I'm not looking to have it overclocked either and my psu is an 850w platinum Superflower.
Thanks in advance for any advice!
To be fair I have the 670 version of the boards and that’s how I put mine in, I really hate adding anything by force.My guess the locking mechanism is too tight so I guess the button should be pushed before you slot the card in?
Yeah I was looking at this version as well, it feels like a sort of downgrade coming from the EVGA 3080ti though lolThe FE should probably be your top choice if space is the issue. It cools very well and is more compact than anything else I have seen. The MSI Ventus 3X OC and OC plus are 2 and a half slots so also could fit if they are not too long. (Card Dimension (mm) 303 x 121 x 49 mm).
The FE's feel very premium and look very professional, they also hold their value well. My only concerns about them is do they suffer the same issue with PCI-e Gen 5 that the 5090 FE does or is the design different, and is the coil whine worse than other brands.Yeah I was looking at this version as well, it feels like a sort of downgrade coming from the EVGA 3080ti though lol
It has 24GB of VRAM which makes it great for running LLMs (AI).That was due to demand from miners though, why so much now?![]()
I got the Asus Prime 5080 OC, its 2.5 slots. Was also eyeing the Gigabyte Windforce SFF 5080.Hi folks,
I can't say I've ever tried to see what happens if I only give my 4090 3x 8pin instead of the full 4x but I guess for 5090 owners it's an easy way to power limit the card without the need for software intervention.GeForce RTX 5090 reportedly works with 3x 8-Pin power adapters, but stays limited to 450W - VideoCardz.com https://search.app/pBgAutbjKY4bhbAh8
Not really. To run any of the deep reasoning LLM you neeed to be running the 70b versions whoch require around 40gb RAM/VramIt has 24GB of VRAM which makes it great for running LLMs (AI).
Yep, which is why neither 4090 nor 5090 are a competition to several pro cards. Yet the price is creeping up to that level each generation. :/Not really. To run any of the deep reasoning LLM you neeed to be running the 70b versions whoch require around 40gb RAM/Vram
The power rating for 2x8pin cables is 150W, but they can probably pull more. One thing to remember is that neither the PSU or GPU will care what cable is connected between them. The GPU will pull as much power as it needs, and the PSU will provide as much power as it can. If the ampage drawn exceeds the cable's tolerance it will melt and possibly burn. I don't recommend pushing limits of industrial safe ratings. Your GPU will come with a cable, you should use the cable provided with the hardware or if used aftermarket cable, then ensure is stated by the manufcaturer to be 100% compatible with your hardware. If you are not sure you could contact Cablemod and follow their guidelines.Is anyone using or planning to use the original 12VHPWR native PSU cable instead of the updated 12V-2x6 cable? I have the Cablemod 600w 12VHPWR 2x8 pin cable for the current 4090 and presumed I would be OK to continue using that for the 5090. I have read some contradicting opinions from googling though.
ATX 3.0 -> ATX 3.1 isn't really an upgrade.Are people using ATX 3.0 power supplies or upgrading to ATX 3.1 for use with teh 5090?
hwbusters.com
Yup. its actualy cheaper to just buy a m4 pro mac mini with 64gb ram and you are good to goYep, which is why neither 4090 nor 5090 are a competition to several pro cards. Yet the price is creeping up to that level each generation. :/
so 2 x 3090s in sli?Not really. To run any of the deep reasoning LLM you neeed to be running the 70b versions whoch require around 40gb RAM/Vram
