Congrats!Just fed my dog a sausage![]()
If you select DLSS and then under it native, that means DLAA which is the best form of AA.DO you guys just use DLSS even if you don't need it. I'm not using it on this and it's fine. Wouldn't mind some raytracing though.
Win11 AutoHDR adds some highlights maybe the odd skin colour at night or try RTX HDR for nVidia GPUs but no native HDR. I also had to lower the gamma slider quite a bit to get decent contrast on my OLED monitor.Getting 55-60fps everything on experimental.
No HDR in this game?
Had my first crash. got killed then couldn't reload just kept making a bong whenever I clicked try again. Also after my latest save I spent about 20 mins fiddling with levelling up and some inv maintenance then I got rekt by some bandit and had to redo it all again. HATE the save mechanic in the game already. Just gimme an F5 quick save ffs
Done, much betterJust download the save anytime mod from Nexus.
GOTY, then ?Just fed my dog a sausage![]()
Experimental kills fps. I get 110fps at 4k with ultra settings, but only 65fps with experimental settings DLSS Preset F (K doesn't work). I can't tell any difference in visual quality between the two, but my eyes aren't as keen as some others on these forums.Getting 55-60fps everything on experimental.
I would say that given what you say there you would likely not enjoy itIs the core gameplay good enough that the game could still appeal to someone who doesn’t really give a toss about having conversations with NPCs and isn’t that interested in story-based games ?
I always go into these types of games with the best of intentions to get immersed but within half an hour I'm just skipping through conversations without a care in the world about the story.
