Yeah using the one from 3 days ago
Hmm only think I can suggest would be to do a ‘proper undervolt’ using the voltage curve, but I expect you’ve already done that.
If not, this is a good instructional vid for a 4090 undervolt but you’d have to play around with the numbers etc to adapt for the 50 series, might require some playing around:
Hope you get it sorted, or if you return and go for an AIB that this solves it for you
