Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Bought a plastic duck
Love it !!!Bought a plastic duck
This alone is a good enough reason to buy one of these new MinisBought a plastic duck
You said earlier it was like my hybrid Logitech.the GPX Superlight 2 acts the same as Razers Scroll Wheel.
Hence I was wondering if I should have got that...It is "Tactile" but only very subtle, so when scrolling webpages you have to scroll slowly to feel the feint individual notches but if you speed up it then "Spins" and you can't track the notches.
Yeah, I miss both of these points. I was wondering if I've seen somewhere something/some software that lets me hold the back but and scroll the mouse for sideways scrolling? Have I imagined that?magnetic notches and you control how much force is needed before it enters freewheel mode. Wish is had side rocker buttons on the wheel like the Keychron though.
Okay... so, holding Shift and scrolling does it sideways! Wh00p!I was wondering if I've seen somewhere something/some software that lets me hold the back but and scroll the mouse for sideways scrolling? Have I imagined that?
Bought a USB-C 40gbps nvme enclosure. The cable supplied is surprisingly nice, even have LED showing current/voltage.
Feels as solid as my OWC costing double, and not sure why it comes with these tiny cable sleeves....
Have just picked it up from getting a service, he has changed the brake pads, chain and fixed a few other issues so all good to go now. Already in the territory of where I probably could have bought something newer and better second-hand. But hey ho!That looks similar to my old Kona (1998) Lavadome. The only thing that remains original are the handlebars, frame itself and v-brake blocks. Everything else got changed or busted. In the end it had mavic titanium wheels, hope hubs, hollow tech II bottom bracket+cranks, XT set (front and back gears+deralliers), SPDs, new seat+post (bent), and mazzochi Z2 BAM light oil shocks. I even have the same cow horns (protected hands from a number of bangs).
If you're going on a ride just shove it in for a service - a new chain and new setup break blocks will go far to freshen the feel of it without spending an arm and a leg.
