Just looking for advice on a screen or screens to pair with a Mac Mini M4 Pro. Obviously the Apple option is the 27inch 5k Apple Display Studio for £1500 but I was thinking that a larger screen would be better. It’s just for work purposes, web design. The budget is £1500. Would two screens that are 5k and 27inch from a different manufacturer work? Or is there a comparably ultra wide? Any help would be appreciated.
Looking like we could get a mini LED Studio Display at some point too based on supply chains.
www.asus.com
Am thinking of buying a new monitor for my Mac, not sure whether to get a 27 inch 4k 120hz or 5k 60hz, would the 5k jump (for perfect 27 inch 1440p) be worth it over the higher refresh rate?
Its quite expensive though, was looking more at the BenQ PD2730S but might just get a 27 4k 120hz+ screen as I think am too used to a high refresh rate monitorIf you’re looking at a Studio Display for your 5K 60hz needs then yes, it’ll be worth it. It is absolutely overpriced for what it is but it’s an exceptionally good monitor. You’ll plug it in and wonder how you’ve managed with a Studio Display hole in your life
Do you have any monitor recommendations?Speaking from experience and lots of research 4k 120hz with better monitor app is the way forward. Studio Display is fantastic but for me involves way too many compromises.
All depends what you want. Whatever you choose there will be compromises. Dell Alienware oled gets a lot of love from people on here. Ultimately it’s up to you, I personally wasn’t willing to spend £800 plus and risk burn in as I use mine for office work. https://www.rtings.com/monitor/reviews/best/gaming-monitors-4kDo you have any monitor recommendations?
Ill have a look at some, probably going to go for something sleek looking like the MacBook and not too bothered about OLED as I have a separate gaming monitor, is more for the ability to use my MacBook with a keyboard and not having to slouch my neck down at the screen.All depends what you want. Whatever you choose there will be compromises. Dell Alienware oled gets a lot of love from people on here. Ultimately it’s up to you, I personally wasn’t willing to spend £800 plus and risk burn in as I use mine for office work. https://www.rtings.com/monitor/reviews/best/gaming-monitors-4k
My thoughts are mostly covered in these responses.All depends what you want. Whatever you choose there will be compromises. Dell Alienware oled gets a lot of love from people on here. Ultimately it’s up to you, I personally wasn’t willing to spend £800 plus and risk burn in as I use mine for office work. https://www.rtings.com/monitor/reviews/best/gaming-monitors-4k
Crazy, isn't it (in a good way). My 2017 iMac is effectively the same panel and that wasn't the first iMac with it.Yes, on paper studio is display is way overpriced however, for my current needs, it is by far the best monitor I’ve ever owned (and I’ve owned a lot).
Just got my shipping notification, will post when I get it.You'll have to update with how you find it.
I've actually been looking at a Mac Studio, but there's nothing I do that is slow on my M1 MacBook Pro. And I was going to get the M4 version in black, but again I figured what's the point for my workflow and bought an extra year of Apple Care instead. I don't think I've ever had a Mac/laptop this long. I think I'll keep it until I can't extend Apple Care on it.I was going to get a Mac Studio as well after this, but I'm editing 6k footage on my M4 Mac Air again today and honestly it would be really hard to justify the expense when this laptop does such a solid job. The occasional little hitch if I scrub the timeline very fast, but otherwise perfect.
