- 28 Jul 2015
Have you applied the bios patch? Any difference?
Yes, I didn't listen it with the old bios before, so I don't know. The silent bios is just a preset fan curve, which I have replicated with the default bios and a custom profile, although I'm not concrete on this.
How is it for coil whine?
Moderate, a little worse than my 4090 FE. If coil whine is a problem for you, I wouldn't go for the Astral. I hear that ASUS cards are pretty bad for coil whine in general.
