- 29 Aug 2010
- Cornwall
Then you're back at the whole not having zero-rpm when setting it manually.Oh i see...
You see in my screenshot where it says "Zero RPM" with an enable slider? turn that off, it will disable Zero RPM and then you can set the fan ramp speed from 20c.
Not really surprising is it? Wouldn't surprise me if Intel had sold more B580 than Nvidia have sold 50 series. As has been said, both companies are probably far more interested in selling cards to businesses for AI than consumers for gaming.
I think the Aorus 5090 got a good review from HUB, let's hope Gigabyte did a good job with the AMD cards too. Gigabyte didn't use PTM7950 on the 9070s though did they, unlike some.Which of the 9070XT models takes your fancy?
I like the Gigabyte Gaming OC and Aorus- they take standard 8 pins and boost to over 3ghz. The only downside is that they have 2 DP and 2 HDMI. I’d have preferred more DP:HDMI.
Don’t know who would stock XFX.
I would also like more HDMI ports, although as I said to someone (might've been you) my last AMD card that had dual HDMI ports (a Sapphire) didn't let me use both at the same time to output 4K@120Hz though (both worked individually). My last Nvidia card with 2 HDMI ports (a Gigabyte) did allow both to do 4K@120Hz at the same time though, so not sure what to expect this time.
