Seem to work fine in real deployments though
Certainly can't imagine going through 26 individual AP's and having to set channels for each of them
It's connecting via 5 GHz.The MacBook is likely connecting on 2.4GHz so if you want speed, look to disable 2.4GHz on a home SSID and have IOT 2.4GHz only radio.
I understand that. I’m probably less than 10 feet away from the AP, direct line of site. iPhone gets 900, Mac gets 400.Free Space Path Loss, as the client moves away from the AP the power will be halved and thus the data rate will drop. Depending on the distance, you may want to look at a second AP if you want near Gbit speeds.
Did you set your U7 to 160mhz, high power and channel 100 just to see how it performs?I understand that. I’m probably less than 10 feet away from the AP, direct line of site. iPhone gets 900, Mac gets 400.
The wall mount isn’t the issue more it doesn’t provide good coverage 360 degrees if I recall? Unless I’m wrong ?U7 Pro Wall has a table mount if you don’t want to wall mount it.
U7 Pro Wall Table Stand - Ubiquiti Store
Lightweight, aluminum table stand for the U7 Pro Wall.uk.store.ui.com
I’m sure cheaper 3rd party options will be available.
Locate multiple in-wall APs around the floor to get coverage? Any AP that wall mounts is going to throw the signal primarily forward, the antenna plots are all here https://help.ui.com/hc/en-us/articles/115005212927-AP-Antenna-Radiation-Patterns#2
was ideallyIt would likely be cheaper and better to have 1 gateway unit and APs for the rest.Too expensive that routewas ideally
Hoping for one a floor.
If i read that right, the u7 outdoor Siri omni antenna might work.
Alternative is u7 express everywhere ?
Yeh but the issue is which APs can be omnidirectional without being ceiling mounted or requiring multiple per floor.It would likely be cheaper and better to have 1 gateway unit and APs for the rest.
Why would anyone want this?Yeh but the issue is which APs can be omnidirectional without being ceiling mounted or requiring multiple per floor.
