Glad you got the sanding pen ok, just finished the first coat of clear seal on the log cabin, felt odd using a 2 inch brush instead of a tiny oneyeah sanding pen has arrived, I'll test it later on the thing I purchased it for. Currently just having a clear out to put some local ads on for the models I decided I won't use, like leftovers from the big chaos boxes, Dark Commune, Cultists etc.
This is so I can feel good before I refill the space with other boxes, though I'm way better than when I first started. EC will be on the shelf for a year until I decide what colour to go with.
Glad you got the sanding pen ok, just finished the first coat of clear seal on the log cabin, felt odd using a 2 inch brush instead of a tiny one![]()
You will get the feel for it, add a bit of water to the area you are sanding and don't press too hard down with the pen.
Was deffo pressing too hard as well but this was an easy bit to practice on as very hard to mess it up. Good tool, thanks for the recco.No problem at all, you will find using the small sanding head makes life a lot easier removing the flash once you have removed the parts from the sprues.I checked your previous message so remembered the wet part at least. Was thinking how will I know if the sandpaper wears out, next minute, orange bits everywhereWas deffo pressing too hard as well but this was an easy bit to practice on as very hard to mess it up. Good tool, thanks for the recco.
I'm not one for customising models much but I had an idea for something for an EC Rhino but I don't think it will be possible, as in it probably is but I don't have the skill and it will be too tricky overall, Juice wont be worth the squeeze as they say.
Got these today. Carbon copy of the Greenworld stuff clips I have for half the price I paid. They must just rebrand the product for different companies. Real handy for airbrushing having two really helps the workflow moving parts back and forth.
It finally happened, a box in which I am missing a base lol. I don't have spares either, but GW were very quick to send me out some spares.
I know they are worth less than pennies but I still thought it was cool that they just did it without even questioning anything like had I even bought the item in the first place.
Saw this at the weekend, guy turned up and was missing a sprue.
Store manager just took another off the shelf, opened it and gave him the missing sprue, no questions asked.
I dunno man, I'm beginning to think we might be paying a fair bit more than what these things cost to make![]()
I think my EC box might be missing a sprue or two![]()
We will have ordered from different places but like do they dispatch it on the release date or is it a bit like game pre-orders where you generally get it a day or two before
Not sure, I know the GW stores get theirs the day before.
