- 3 Oct 2012
I have ran Windows Diagnostics and there were no issues found with the RAM.Run memtest and see if there's any ram errors
Windows diagnostics does not show up intermittently faulty ram. You'd need a full memtest to do thatI have ran Windows Diagnostics and there were no issues found with the RAM.
Just to check, you are using 2 separate cables from the PSU to the GPU, and not one cable that splits in to 2 at the GPU?The GPU has 2 x 8 pin connectors. I have slotted in a 6+2 connector into each.
I have PBO enabled now (I removed the 65 wattage) but what is CO?
The cooler is a Noctua NH-U12A and this has been refitted with new new thermal paste, problems persist though.
Long post so kind of lost track
So may ask something already asked before
At least can probably rule out windows now
Unless its a 24h2 issue
Is it only games causing a problem?
All games or specific games?
Does looping a gpu benchmark for an equivalent length
of time cause same problem?
Monitoring temperature when it crashes?
Cpu and gpu temperature
Motherboard on latest bios?
And yes run memtest
Got any friends or family with compatible hardware
Where you could double check stuff?
New cpu have integrated graphics?
If so does it happen on igpu instead of gpu?
Windows ram diagnostic may not be
As thorough a test as memtest
Still better than not testing the ram though
Yeah new PSU should arrive next week, I'm leaning towards this being the culprit.Ideally yes you want 2 separate 8 pin cables
Not a pigtail cable
Though my 3080ti has no issues using pigtail
With an 850w psu
Even in unleashed mode at 400w
And think its original psu and gpu they're using
So while possible it's a less likely issue
Unless new cpu is drawing a load more power
Think they ordered a new psu anyway
So once that's installed
Can see if there's any change to the situation
Edit
3 x 8 pin on my 3080ti not 2
1 separate cable and 1 into 2 x 8 pin pigtail
Wouldn't try 400w through just 2 x 8 pin
That sounds like memory issues.or crash as I exit the game (PUBG and Cyberpunk).
that tutorial is bullocksThe tutorial I watched said to do it that way, but I regret doing so now!
SSD
Do you have a 970 Evo Plus?
If you do, download CrystalDiskInfo and post the SMART results here.
Check your firmware is safe (not one of the affected ones).
^^ Done this yet?All games, either crash when playing (Minecraft every time) or crash as I exit the game (PUBG and Cyberpunk).
It is 970 Evo plus, but that was in the previous unit and worked fine, so is it still worth running these tests?^^ Done this yet?
Probably not the problem if the drive is old, but worth checking because there's known issue with these drives.
There are no tests, downloading CrystalDiskInfo or checking on Samsung's Magician takes just a few minutes. Would take longer to post the screenshot for us to look at.It is 970 Evo plus, but that was in the previous unit and worked fine, so is it still worth running these tests?
New PSU has arrived. Unfortunately it will be another week before Memtest86 has completed its checks.
