Escape from Tarkov
What is prestige?
Essentially a progress system,
Getting kappa, lvl 55, and resetting your account while maintaining your stats etc
In short a time dump :D
Hi guys does anyone know how you reset your wish list items on Escape from Tarkov? I've tried it in options and un-ticking them manually but loads are still lit up. Even Google is not really helping.
Well, on a case by case basis you click on 'add to wishlist' again and you get the option of removing it. As to actually resetting it all... no idea
Yeah so i've tried that and for some reason the "remove" button is greyed out. I'm trying to finish off my Hideout and when I started I basically added everything - now that i'm only building level 3 things I don't need everything highlighted.
you can clear it in the first settings screen, think it's under "game" and then just above where you select your FOV, there is a option to clear whishlist.
