- 24 Mar 2018
- Brighton
They seem to have worked out the DoH properly now, been testing 7.18 for the last 24hrs. so for that reason alone It's worth the bother for me now!Worth updating to?
A 16-core ARM64 clocked at 2GHz is pretty beefy, it will do about 16Gbps with some filter rules.
/certificate/builtin/print
Columns: ORGANIZATION, COMMON-NAME, INVALID-BEFORE, INVALID-AFTER
# ORGANIZATION COMMON-NAME INVALID-BEFORE INVALID-AFTER
0 DigiCert Inc DigiCert Assured ID Root CA 2006-11-10 01:00:00 2031-11-10 01:00:00
1 DigiCert Inc DigiCert Assured ID Root G2 2013-08-01 13:00:00 2038-01-15 13:00:00
2 DigiCert Inc DigiCert Assured ID Root G3 2013-08-01 13:00:00 2038-01-15 13:00:00
3 DigiCert Inc DigiCert Global Root CA 2006-11-10 01:00:00 2031-11-10 01:00:00
4 DigiCert Inc DigiCert Global Root G2 2013-08-01 13:00:00 2038-01-15 13:00:00
5 DigiCert Inc DigiCert Global Root G3 2013-08-01 13:00:00 2038-01-15 13:00:00
6 DigiCert Inc DigiCert High Assurance EV Root CA 2006-11-10 01:00:00 2031-11-10 01:00:00
7 DigiCert, Inc. DigiCert TLS ECC P384 Root G5 2021-01-15 01:00:00 2046-01-15 00:59:59
8 DigiCert, Inc. DigiCert TLS RSA4096 Root G5 2021-01-15 01:00:00 2046-01-15 00:59:59
9 DigiCert Inc DigiCert Trusted Root G4 2013-08-01 13:00:00 2038-01-15 13:00:00
10 GlobalSign GlobalSign 2012-11-13 01:00:00 2038-01-19 04:14:07
11 GlobalSign nv-sa GlobalSign Root CA 1998-09-01 13:00:00 2028-01-28 13:00:00
12 GlobalSign GlobalSign 2009-03-18 11:00:00 2029-03-18 11:00:00
13 GlobalSign GlobalSign 2014-12-10 01:00:00 2034-12-10 01:00:00
14 GlobalSign nv-sa GlobalSign Root E46 2019-03-20 01:00:00 2046-03-20 01:00:00
15 GlobalSign nv-sa GlobalSign Root R46 2019-03-20 01:00:00 2046-03-20 01:00:00
16 The Go Daddy Group, Inc. 2004-06-29 18:06:20 2034-06-29 18:06:20
17 GoDaddy.com, Inc. Go Daddy Root Certificate Authority - G2 2009-09-01 01:00:00 2038-01-01 00:59:59
18 Internet Security Research Group ISRG Root X1 2015-06-04 12:04:38 2035-06-04 12:04:38
19 Internet Security Research Group ISRG Root X2 2020-09-04 01:00:00 2040-09-17 17:00:00
20 Sectigo Limited Sectigo Public Server Authentication Root E46 2021-03-22 01:00:00 2046-03-22 00:59:59
21 Sectigo Limited Sectigo Public Server Authentication Root R46 2021-03-22 01:00:00 2046-03-22 00:59:59
22 The USERTRUST Network USERTrust ECC Certification Authority 2010-02-01 01:00:00 2038-01-19 00:59:59
23 The USERTRUST Network USERTrust RSA Certification Authority 2010-02-01 01:00:00 2038-01-19 00:59:59
Oh man that doesn't sound like fun. Hmm. So would you say the interface is easy enough to use or is it all CLI? Given I only have experience with normal consumer based routers. Your Asus, Zyxel, Tplink, etc. I'm not an IT noob though so can work things out.Their support more or less doesn't exist, there's a forum you can post on which is maybe 40% as hostile as Linux users are to getting asked questions they think are too basic. You either need to have a decent idea of what you're doing or use a good reseller who can provide that help.
I have a 4G MikroTik router and it's been fine for the probably six years that it's been installed for.
They have a GUI, but there is no handholding. Text based.Oh man that doesn't sound like fun. Hmm. So would you say the interface is easy enough to use or is it all CLI? Given I only have experience with normal consumer based routers. Your Asus, Zyxel, Tplink, etc. I'm not an IT noob though so can work things out.I don't actually know what the GUI looks like for MikroTik. Is it flashy or quite text based?
Thanks yeah that is quite different isn't it!They have a GUI, but there is no handholding. Text based.
