2.1.4.3 same bios, tried different driver same thing, I think its gone a bit wonky, this controler does have issues widely reported, WIFI connects straight away. Cheers.
Had a lot of problems with the NIC on this board, my AM4 PC has the same NIC and never had any issues with that. I gave up and got a USB NIC and that just works.Anyone with this mobo say how long it takes for the ethernet to connect after a reboot/power on. Mine use to connect as soon as on desktop, now I'm wating a good 30 seconds.
AGESA ComboAM5 PI 1.2.0.3f is a BIOS update for AMD AM5 motherboards. It focuses on improving system stability, enhancing memory support, and adding compatibility for upcoming AMD Ryzen 9000 series processors, including the "F" series with disabled integrated graphics. The update also includes security fixes, particularly addressing the fTPM vulnerability.
Here's a more detailed breakdown:
- New CPU Support:
The update adds support for upcoming AMD Ryzen 9000 series processors, including the "F" series (e.g., Ryzen 7 9700F) which lack integrated graphics.
- Enhanced Memory Support:
AGESA 1.2.0.3f improves compatibility and support for higher capacity RAM modules, potentially up to 256GB (4x64GB).
- Security Fixes:
The update continues to address the fTPM vulnerability, which was previously addressed in earlier 1.2.0.3 versions.
- Overall Stability and Performance:
The update also includes general improvements to system stability, device compatibility, and overclocking support.
thanks for this. I have updatedThere's an updated chipset driver on the Support site: AMD Chipset driver v7.06.24.2226
Downloads fine for me - no virus detected. Using Firefox. I checked on Chrome too and that downloads fine.I see the Wireless and BT drivers have been updated on the Support site (they've been up elsewhere since July - and those have worked well for me)
However, the wireless driver on the Support site gets flagged as a virus on my side - anyone else?
Driver details:
MediaTek WiFi Driver v3.4.0.1329 for Windows 10/11 64-bit.
Version 3.4.0.1329
10.63 MB 2025/10/07
SHA-256 :1E81AB5C28451646E280751E5BBC87CC73E2610665CC39573848BA9A96C9CD45
Nice one, thanks Nabinium. I retried there, and no issues this time.Downloads fine for me - no virus detected. Using Firefox. I checked on Chrome too and that downloads fine.
You on latest BIOS update? Can you get into BIOS and load BIOS defaults?ttempting to swap GPU. Put old GPU back in and
