New build for niece
doesnt have to look similar if its replicating my build for one of them. Wouldnt want them arguing that 1 is more powerful than the other. They can look different, but if they perform at the same kind of level then ideal :)
Right, got it.
The CPU is roughly equivalent, I've done the same size of memory (doesn't make sense to buy DDR4 at current prices) and a graphics card that is close(ish).
My basket at OcUK:
Total: £1,012.78 (includes delivery: £11.98)​
why spend 1k on a old intel package with no upgrade path..not really understanding this...just get a 9600x b650/b850 setup..at least down the line you can shove in an x3d cpu down the line if their gaming hobby continues
You have just made me think that your right and the original suggestion of the 9600 build should be built.
Omg lol. What to do. Everyone has been so so helpful
if it helps, I have 2 kids, one's just starting uni in 2 weeks and other just starting his A levels(as of yesterday)..My eldest has a B550 am4 setup with a 5800x cpu/3080fe combo I built a few years ago. My yougest I built a pc for him as he starts computer science a levels...his machine was actually cheaper as used some 2nd hand parts, but also more potential as a b650/7800x3d machine with a 7800Xt gpu (gpu on a par for raster with 3080 roughly, looses out to dlss as only fsr3, but does have 16gb vram)...cpu for gaming wipes the floor with the 5800x
my eldest isn't jealous that basically my youngest has a better gaming rig than he does...he realises pc's improve over time and that for a few years he had a rig when his brother didn't. He does now want to upgrade his pc for his b'day/xmas which is fine..i picked up a 2nd hand 7800x3d for him a month or so back and will prob go for a b850 tomahawk(available £193 if you look), with some 32gg 6000c30 rgb ram(has to be rgb for my kids..ad me for that matter..after having years of nothing, I enjoy the rgb)
as side note my sister doesn't have kids so spends money on mine instead...They're her only 2 nephews, so she got my eldest a scuba diving course for his open padi/open water padi etc last present...she wants to do something similar for yougest now he's getting old enough, but he's happy to wait till he finds something he wants to do
my jist is don't worry too much of getting everything perfectly the same. At the end of the day, theses are presents and hopefully your niece/nephew realise this and also realise if presents come at different times then in the case of pc's, if money is roughly the same, performance might change as time has gone by. hopefully they understand this, and also means they get to look forward to future upgrades/presents (if they still enjoy gaming in the future)..my sister lets me do the pc stuff, she likes doing the outdoor stuff to counterbalance it :cry: ...which is fine...gave me an excuse to dive with my son, and get my dry suit certificate at the same time (never dived in uk before...it's chilly)
While this make sense in terms of upgradability you said that you wanted to have bot nephew and niece the same computer almost. Secondly you can utilise some of your existing memory therefore a cheaper upgrade plus if there are on the same platform you can easily cross troubleshoot.
Yeah I am probably worrying too much about it. As they do understand everything you have all said.
Is the saving from pulling out/sharing the 32GB of RAM meaningful to you, or not really?
If it isn't and you think you'll get away with it, I would just build the best PC for the budget, rather than trying to match them.
Not really, no. Will just as happy keep the ram where it is.
in that case, I'd just go AM5, yeah (and buy a new set). It doesn't make sense to buy DDR4 anymore, it used to be cheap, but unfortunately it isn't anymore.
For more or less the same money, maybe this (CPU cooler in CPU box):
Edit: might be better to get a cheaper SSD and a 9600 (9600X has no cooler).
My basket at OcUK:
Total: £1,014.79 (includes delivery: £11.98)​
9060 XT 16GB is a lot faster, but they lose 16GB of system RAM and the CPU has half the number of cores.
So, even though it'll actually perform better in games, you can tell them (the 12700/64GB/3060 owner) that they weren't short changed :D
I'm a little different as want a mobo that can handle any cpu you can throw at it(after all, half the point going am5 is the future upgradeability). also 32gb ram is fine for general gaming (i don't come close), so will give up some capacity at 48gb, and rather have faster ram so 6000 c36. ideally 6000c30
9600X £172.75
32gb corsair 6000C36 expo £83.99...they have veangeance rgb 6400c36 expo for £91.99...that'll run but could manually just set it to 6000 speed also
wd sn7100 2tb ssd £106.99
mag b850 tomahawk max wifi £194.01
MSI mag a850gl psu £97.99
then from ocuk
lian li v100 case £69.98 (comes with 4 argb fans)
powercolour reaper 9070 £499 (roughly 50% faster than the 9060xt)
thermalright assassin spirit 120 evo argb £16.99
that £1241.7 which is just over the £1200 budget you set but will be a very capable 1440p gaming pc (so will rip through 1080p), and should be ok with 4k with upscaling
below is idea of performance as uses a 9600x with a 9070...guy does a lot of 'low'detail for competetive shooting to max framerates, but other games has it set to ultra. only game that used more than 20gb ram was hogwarts legacy which came in at 21gb (why i prefer faster 32gb ram to slower higher gb ram)
This has went way bigger than i ever intended.
For my existing machine that's the 12700f, 64gb ram, 3060 12gb - thinking just adding a better cooler to the CPU (one of the Thermalright coolers, just hoping its easy or it probably doesn't actually need it running the way it is) - Passing this on to my nephew
My nieces new build which is aiming for as near £1k budget that i still cant decide on due to all the fab advice. Could we narrow the build down for her build, defo going to go the AMD route (does going white add a lot to budget) 9060XT already got.
my new build, to separate the ideas I'm going to make a separate post as ill end up getting confused.
