- 4 Nov 2012
doesnt have to look similar if its replicating my build for one of them. Wouldnt want them arguing that 1 is more powerful than the other. They can look different, but if they perform at the same kind of level then ideal
Right, got it.doesnt have to look similar if its replicating my build for one of them. Wouldnt want them arguing that 1 is more powerful than the other. They can look different, but if they perform at the same kind of level then ideal![]()
Hes got 64gb in his pc could pull out 32gb and save some money if it's 16gb sticksRight, got it.
The CPU is roughly equivalent, I've done the same size of memory (doesn't make sense to buy DDR4 at current prices) and a graphics card that is close(ish).
Oh, smart! I didn't think of that!Hes got 64gb in his pc could pull out 32gb and save some money if it's 16gb sticks
Would have to change the board in my spec to DDR4.Do you mean pull 32gb out of my current machine, and leave it with 32gb ddr4 in both?Oh, smart! I didn't think of that!Would have to change the board in my spec to DDR4.
We do.Do you mean pull 32gb out of my current machine, and leave it with 32gb ddr4 in both?
Thank you both so so much, it now appears that I am going to be busy along with them.@nutski1873
Swap out the motherboard for the MSI B760 GAMING PLUS WIFI DDR4 which can be had for £110 from tetras build and use your 32gb from your pc .
Just holler if you have any questions and let's us know how you get on.Thank you both so so much, it now appears that I am going to be busy along with them.
You have just made me think that your right and the original suggestion of the 9600 build should be built.why spend 1k on a old intel package with no upgrade path..not really understanding this...just get a 9600x b650/b850 setup..at least down the line you can shove in an x3d cpu down the line if their gaming hobby continues
if it helps, I have 2 kids, one's just starting uni in 2 weeks and other just starting his A levels(as of yesterday)..My eldest has a B550 am4 setup with a 5800x cpu/3080fe combo I built a few years ago. My yougest I built a pc for him as he starts computer science a levels...his machine was actually cheaper as used some 2nd hand parts, but also more potential as a b650/7800x3d machine with a 7800Xt gpu (gpu on a par for raster with 3080 roughly, looses out to dlss as only fsr3, but does have 16gb vram)...cpu for gaming wipes the floor with the 5800xYou have just made me think that your right and the original suggestion of the 9600 build should be built.
Omg lol. What to do. Everyone has been so so helpful
...which is fine...gave me an excuse to dive with my son, and get my dry suit certificate at the same time (never dived in uk before...it's chilly)While this make sense in terms of upgradability you said that you wanted to have bot nephew and niece the same computer almost. Secondly you can utilise some of your existing memory therefore a cheaper upgrade plus if there are on the same platform you can easily cross troubleshoot.You have just made me think that your right and the original suggestion of the 9600 build should be built.
Is the saving from pulling out/sharing the 32GB of RAM meaningful to you, or not really?Yeah I am probably worrying too much about it. As they do understand everything you have all said.
Not really, no. Will just as happy keep the ram where it is.Is the saving from pulling out/sharing the 32GB of RAM meaningful to you, or not really?
If it isn't and you think you'll get away with it, I would just build the best PC for the budget, rather than trying to match them.
in that case, I'd just go AM5, yeah (and buy a new set). It doesn't make sense to buy DDR4 anymore, it used to be cheap, but unfortunately it isn't anymore.Not really, no. Will just as happy keep the ram where it is.
