AMD Zen 6 rumours
Is that due to cooling restraints ecte...? This is what makes me suspicious about Laptop review's, they say its great and they give it their silly seal of approval....... but is it any good? You're only testing it against its self and i think therefore its probably a POS because you're not willing to compare it to others.
im only interested in laptops for work/productivity so i look at stuff like battery life, performances etc. macbook is unfortunaly still king mate.
This looks like quite an interesting development, if it's used in Zen 6. Would result in lower latency to memory and between cores.
Could be huge but might be zen7 or zen8 seeing as zen6 is probably already in development
Zen6 on AM5 was pretty much confirmed by AMD themselves ages ago though, wasn't it?
Some rumours have Zen7 on AM5 too. I guess that is all down to where AMD projects the price of DDR6 to be when Zen7 launches.
Servers may get it then but forcing consumer CPUs to do so is very risky and they hopefully learned some lession from AM5. That Intel ADL was available with DDR4 and DDR5 was a big selling point while DDR5 was far more expensive than DDR4. Irony being that with mainstream desktop Ryzen being chiplet + IOD it would have been easy for AMD to have made a DDR4 option for Zen4
I assume we are still in the position of AMD stating that they will continue to support the AM5 socket, and those boards will support future CPU's that are launched for it.
But, again I might have missed something official from AMD, I have not seen in noted that Zen6 will be released on the AM5 platform, no matter how likely that could seem.
Just as AMD continue to support and release CPU's for AM4, it might not mean that AM5 will get Zen 6, but AM5 should have other releases for it.
Anyone seen anything different from AMD, and not just rumours..?
It seems highly likely that Zen6 will be compatible with AM5 motherboards, which I think is what you're asking...
That is what as been rumoured for some time now. From a link above it shows MSI's reps response when asked, "future CPU ready".
With what is continuing with Intel and their 1851 probable single CPU revision socket, perhaps a refresh only incoming at some point, I would have liked to have read an AMD's announcement that AM5 existing motherboards would definitely support the up and coming Zen 6 CPU's. Although that article, take from it what you will, linked to certain design changes being made to some 800 series boards for possible compatibility with Zen 6.
If Zen 6 is due to appear next year, I suppose at some point, hopefully this year, AMD will make such an announcement. Then, at least, we might be better informed of such compatibility and its possible limitations.
The sea of wires concept is already used on Zen5 cpus (Strix Halo) and is hugely impressive.
Zen6 is a cpu architecture like Zen5. It requires interconnects between chiplets - either serdes or "sea of wires". Its not a major fabrication issue to produce both types.
The sea of wires is actually an additional layer on the substrate and is cutting edge, although Strix Halo has proved it can be made in volume.
The power saving from removing serdes is staggering. Basically you have a 9950X on Strix Halo which idles at 2-3W. If you look at the same desktop cpu it'll probably idle at 35W. That's the base power cost of serdes and all the timing/power issues it brings with it.
Strix Halo has worked as a proving ground for sure.
"Sea of wires" is the future which I find amusing as I'm old enough to remember when we had to serialise to prevent x-talk. What goes around.... :D
Oh nice then, does sound very intriguing!
Future looking good for AMD
"AMD’s anticipated Zen 6 architecture may not arrive until 2027, marking a significant shift from the company’s established release rhythm. Originally targeted for mid-2026, the Ryzen 11000 series could be facing a year-long delay attributed to changes in TSMC’s advanced node production plan."
Oh apparently this source is MLID, so take with a pinch of salt.
I was, up until around a month ago fully invested in keeping my AM4 5800X3D setup until AM6 arrived.
However, The more I looked into AM6, possible delays plus never really going for a first adopter into a new socket (Prefer to wait until issues are ironed out) it had me thinking.
After seeing a member on here selling a 9700X for a good price, I decided to pull the trigger and jump ship to AM5, At least now I have an upgrade path if I require and likely will get another X3D chip down the line.
The swap from AM4 to AM5 cost me £148 so felt like a no brainer really.
I'm still interested in seeing what AM6 has to offer of course.
Maybe he's just jumping on the bandwagon because it's been expected for a while - both amd and Nvidia GPUs seem to only be 2027 too and it's what I've been predicting on this forum for several months now when I've stated that I believe 2026 will most likely be a dry year for hardware with no major new product releases
AM6 is a long ways off if it's true that AM6 needs DDR6
Don't expect AM6 till 2029/2030 because according to this roadmap DDR6 won't be arriving till then
MLID info so that means they will announce them at CES 2026 :D
