Summer is very short here in Finland and when it starts I put my AC on lol. (Yeah Im not from UK, hopefully Im welcome anyway).Excellent results!
Wait until summer rolls around![]()
Living the PC builders dream in a cold climate. Most welcome!Summer is very short here in Finland and when it starts I put my AC on lol. (Yeah Im not from UK, hopefully Im welcome anyway).
Thanks for getting in touch - love your build and pretty much set on transplanting my son's rig from the Lancool 3 into an O11D Evo.Upgraded GPU from 3080 to 5090. Upgraded Linkup gen4 riser to Linkup gen5.
Redone the loop few times and here we go
Tried convincing myself I didn't need to watercool when I got the Xikii case but that only lasted a few months! Couldn't help myself.
https://i.~ibb.co~/S4XrrHz2/IMG-1547.jpg https://i.~ibb.co~/d0HGvx3t/IMG-9211.jpg
Ended up cooling the RAM & NVME too. Might go back and try to find a VRM block as they can reach 100C+ during 30+ mins of cinebench.
https://i.~ibb.co~/TDQMtZ6w/IMG-1473.jpg https://i.~ibb.co~/KcdK53gw/IMG-1358.jpg
You can also add brass passthroughs with threaded holes for fittings.
https://i.~ibb.co~/LDMhSQJH/IMG-1285.jpghttps://i.~ibb.co~/rGLSkYnB/IMG-1476.jpg
MO-RA sits hidden behind the desk. Managed to get a spare Astral cooler off ebay and modified it with a hacksaw to keep the aesthetic.
https://i.~ibb.co~/yn67YKpT/IMG-1541.jpg https://i.~ibb.co~/0R5wY7N5/IMG-1535.jpghttps://i.~ibb.co~/B289YxhD/IMG-1536.jpg
Sorry mate, your pics aren't showing in your post, nor the quoted post under yoursTried convincing myself I didn't need to watercool when I got the Xikii case but that only lasted a few months! Couldn't help myself.
[/snip]
Cheers for the heads up should be fixed now. Hard finding a decent image hosting site these days.Sorry mate, your pics aren't showing in your post, nor the quoted post under yours
That is a STUNNING build. Mind boggling work on the hard tubing over the motherboard.Cheers for the heads up should be fixed now. Hard finding a decent image hosting site these days.
Cheers, I'm using postimages now although that also had problems in the past.That is a STUNNING build. Mind boggling work on the hard tubing over the motherboard.
What image hosting are you using? I've always used ~imgbb~ but it's being discouraged.
really nice build mateTried convincing myself I didn't need to watercool when I got the Xikii case but that only lasted a few months! Couldn't help myself.
Use a separate PSU to power the pump and fill her up. Use de-ionised/distilled water with a biocide for ultra low maintenance and minimal conductivity risk.Quick power-on check before I decide whether to risk filling the loop without a pressure-test, or hold fire...
https://i.~ibb.co~/gLGQNkWL/PXL-20260216-180447836.jpg
Don't necessarily need a separate psuUse a separate PSU to power the pump and fill her up. Use de-ionised/distilled water with a biocide for ultra low maintenance and minimal conductivity risk.
