Thanks for reminding me, just sent in my objectionThe more emails they get, the better. Even if you ask AI to write you an email expressing your dissatisfaction about the merger it's better than nothing.
Have you reset the ONT since upgrading?I upgraded my you1000 to you200 mid contract and saved £3 a month so now only £30. No skin feeling which is great. Only issue is I have a 2.5 gb usb rj45 adapter but seen to only be getting 1gb downloads even though says connected at the correct speed. Just need youfibre to test my connection. But overall happy with the service and can recommend them
Does anyone know where I can find a technical spec of their new routers, they dont seem to be able to supply one (have tried multiple request to them!)![]()
I noticed this over on the YouFibre reddit and thought I'd repost it here. It looks like YouFibre are going to be rolling out new YouFibre WiFi 7 routers and YouMesh WiFi 7 Boosters to new customers going forward.
YouFibre Hub (FAST 5598 YF) - User Guide
YouFibre Hub Pro (FAST5599 YOUFIBRE) - User Guide
YouMesh Booster (FAST 281 YOUFIBRE) - User Guide
https://www.youfibre.com/setup/
They're all rebadged Sagemcom units.
I'll have another think about it then. Aquiss have been solid for me the last 2 years or so - had one outage (totally not their fault - due to someone digging up a cable...), and it was nice to speak to someone who actually knew what they were talking about rather than having to jump through hoops following a script with generic call taker #6739836 multiple times before getting any progress
