Nvidia increased memory prices on AIB's and most e-tailers have followed suite in advance perhaps.Looks like 5090 prices have gone up
BUT BUT It's user error..Unbelievable. Yet Nvidia keep persisting with this stupid connector.
Jonathan Pryce's Bond villain Elliot Carver "I am now starting to think this was done by purpose and by design to add another planned obsolescense feature.
Just in time for more silly priced new 5090 modelsLooks like 5090 prices have gone up
Did you try another GPU? It could be the slot, or your GPU. Sorry to hear. This issue happened with my 5090 FE.Think my GPU is broke. Booted into a black screen. Motherboard post code is 9C which is reported to usually be USB device issue. Unplugged all USB but same issue.
Plugged my monitor into the onboard vga and i can boot and see windows. Windows is reporting a code 43 error on my 5090.
I have tried:
Reconnecting the power cables
Reseating the card
Cleared CMOS
Safe mode DDU to uninstall the nvidia drivers
Rolled back drivers (although this never happened after a driver update).
Tried changing PCIE link speed in the bios.
Turned off fast boot
Anyone have any other suggestions for me to try?
The onboard works. Can't easily try another slot at the moment due to waterloop and not enough slack to move the card over. When i have more time this evening i will drain the loop and try a different slot.Did you try another GPU? It could be the slot, or your GPU. Sorry to hear. This issue happened with my 5090 FE.
Due to less current at 48v presumably?![]()
ASUS shows RTX 5090 running at 48V with 1000W through a single 16-pin power cable - VideoCardz.com
ASUS demos 48V GeForce RTX 5090 set to 1000W Yes, one cable. ASUS is not only showing a generic 48V power architecture. The demo system uses avideocardz.com
So far the smartest way to deal with that connector issues but reality is it needs to be replaced with something safer. If you understand how electricity works you will understand the reason of 48V used if not you will not understand the "fix" is actually safer than 12V currently used.
YupDue to less current at 48v presumably?
Yeah, 25% of the current will make a HUGE difference. Wonder why this wasn't a thing once the world discovered how **** that connector is.
I'm guessing that 24v wasn't an option due to PoE being 48 to 56 volts and therefore easier to implement.
