So if I wanted to see the power usage of my home assistant on the dashboard, would I need a zigbee plug for the integration?
there we go....
The weekly and monthly sensors show 0 still, as I set them up after the last meter reading was taken, the Today sensor I created befoe the latest reading. But eventually they will correct.
Well this is looking promising....
Popped in an old USB BT Adapter
Shared it to the HA VM in Proxmox
Started the addon and it's picked up the adapter, no need for a reboot or restart either
Spookily I’ve been trying this today, got the adapter added but the speaker kept disconnecting.Well this is looking promising....
I used MPD, will try sendspin a tryWell this didn't go well
is a farce depending on decades old MPD to do the lifting ... getting it into HA is a PITA and an unwanted dependency![]()
GitHub - scyto/ha-bluetooth-audio-manager: Home Assistant add-on for managing Bluetooth audio device connections (A2DP) with persistent pairing, auto-reconnect, and AppArmor security.
Home Assistant add-on for managing Bluetooth audio device connections (A2DP) with persistent pairing, auto-reconnect, and AppArmor security. - scyto/ha-bluetooth-audio-managergithub.com
The future is sendspin this integrates beautifully into HA and music assistant
GitHub - trudenboy/sendspin-bt-bridge: Make any Bluetooth speaker smart. DIY multi-room audio with Music Assistant, Home Assistant AI automations & Sendspin protocol. Docker, HA addon, Raspberry Pi, Proxmox LXC. Free & open-source.
Make any Bluetooth speaker smart. DIY multi-room audio with Music Assistant, Home Assistant AI automations & Sendspin protocol. Docker, HA addon, Raspberry Pi, Proxmox LXC. Free & open-sour...github.com
Did you manage that?
AI suggested I should use a usb extension cable to avoid interference, how did you connect yours?
What BT dongle are you using?Yeah the usb extension is highly recommended... I have everything extended away from the rack - BT dongles, RTL-SDR dongle and the Zigbee dongle - well away from wifi aps and the rack
Q4: What can I do if the Bluetooth adapter has a weak signal? How to improve the Bluetooth range?
1. Change to another USB port or use a USB extension cable
Move the adapter to a front USB port, or use a USB 2.0 extension cable to position it away from the back of the computer. Because there is a lot of random radio noise generated by the processor and system parts, which will cause the short-range and cut-off issue.
An Intel white paper confirmed that poorly shielded USB 3.0 ports will cause radio interference. If your device has range issues when plugged into a USB 3.0 port, a USB extension cable can help.
@Subliminal Aura - The fix to my bluetooth issues (lack of range) was a few ESP32's running as bluetooth proxies.
I setup the HandyHat HACS integration ages ago when I first messed with HA but with that being abandoned, what's the current best / recommend way to get electric consumption figures in? I expect it's still via some combination of the Glowmarkt API?
I've got some more P110 plugs coming today so I can get specific consumption figures for more devices.
This is the kind of dependency bought into the chain that I'm trying to avoid, have you ever monitored the uptime of an esp32 ?
The whole point from my original post is to have a rock solid 24/7 solution without any breaks in service
Frankly the easiest would be the octopus mini, but does require you to use Octopus as a provider.
I've never noticed my esp's going offline that frequently, I'm sure they manage weeks of uptime. Annoyingly I updated them all yesterday so that's reset the uptime.
Have you looked at the logs to determine why it's rebooting?
