- 7 Sep 2020
- Gods Country
ive just intergrated my trading 212 account into HA to show investment data
Call it "Returns Neutraliser"That's a great idea.
I can already think of an automation that turns up the thermostat when your stock portfolio goes up
not if you have a manual thermostat you cant lolThat's a great idea.
Have you tried this yet? If this is the same project that I looked at recently then it looks complicated!Sorry about that, sharing links from mobile not working ?
Finally ....
_
__ _ _ __ ___ ___ _ __ ___| |_
/ _' | '_ ' _ \ / _ \| '_ \ / _ \ __|
| (_| | | | | | | (_) | | | | __/ |_ (-fastbrick)
\__,_|_| |_| |_|\___/|_| |_|\___|\__|
by k4y0z & r0rt1z2
Make sure device is in fastboot mode and connected!
Detected: BISCUIT - Echo Dot 2nd Generation - 2016
LK build: 63cb91b-20221007_072309
Will use payload: fastbrick-20221007.img
Run amonet-fastbrick to unlock the bootloader? (Type "YES" to continue): YES
Sending payload, this might take a few attempts...
Exploit most likely successful!
Please wait until the process finishes and DO NOT INTERRUPT IT.
Press any key to exit...
C:\Users\subliminal_aura\Downloads\amonet-biscuit-v2.0.0\amonet>adb devices -l
* daemon not running; starting now at tcp:5037
* daemon started successfully
List of devices attached
G090L90971351CQG recovery product:omni_biscuit model:Echo_Dot__2nd_Gen_ device:biscuit transport_id:1
C:\Users\subliminal_aura\Downloads\amonet-biscuit-v2.0.0\amonet>adb shell twrp wipe cache
Formatting Cache using mke2fs...
Done.
Done processing script file
C:\Users\subliminal_aura\Downloads\amonet-biscuit-v2.0.0\amonet>adb shell twrp wipe data
Wiping data without wiping /data/media ...
Done.
Done.
Done.
Done.
Done.
C:\Users\subliminal_aura\Downloads\amonet-biscuit-v2.0.0\amonet>cd ..
C:\Users\subliminal_aura\Downloads\amonet-biscuit-v2.0.0>cd ..
C:\Users\subliminal_aura\Downloads>adb push update-kindle-biscuit_puffin-NS65741_user_8146_0013222531716.bin /sdcard/update.zip
update-kindle-biscuit_puffin-NS65741_user_8146_00132225317...e pushed, 0 skipped. 20.3 MB/s (108873539 bytes in 5.110s)
C:\Users\subliminal_aura\Downloads>adb shell twrp install /sdcard/update.zip
Installing zip file '/sdcard/update.zip'
Unmounting System...
Flashing A/B zip to inactive slot: B
Step 1/2Step 2/2To flash additional zips, please reboot recovery to switch to the updated slot.
C:\Users\subliminal_aura\Downloads>adb shell bcbtool set_active b
Active slot set to b.
C:\Users\subliminal_aura\Downloads>adb reboot recovery
Flashing A/B zip to inactive slot: A
C:\Users\subliminal_aura\Downloads>adb push boot-root.zip /sdcard/
boot-root.zip: 1 file pushed, 0 skipped. 127.1 MB/s (473633 bytes in 0.004s)
C:\Users\subliminal_aura\Downloads>adb shell twrp install /sdcard/boot-root.zip
Installing zip file '/sdcard/boot-root.zip'
- info slot _a: patching boot cmdline
- info slot _a: disabling dm-verity
- info slot _a: mounting system
- info slot _a: patching properties
- info slot _a: installing fos flags override
- info slot _a: patching adbd
- info slot _a: patching selinux policy
- info slot _a: patching fstab.mt8163
- info slot _a: neutering ota updates
- info slot _b: patching boot cmdline
- info slot _b: disabling dm-verity
- info slot _b: mounting system
- info slot _b: patching properties
- info slot _b: installing fos flags override
- info slot _b: patching adbd
- info slot _b: patching selinux policy
- info slot _b: patching fstab.mt8163
- info slot _b: neutering ota updates
- info done
biscuit_puffin:/ # ls
acct fstab.zram init.mt8163.rc init.whad_cc.rc sbin
bugreports init init.mt8163.usb.rc lost+found sdcard
cache init.ace.rc init.mt8163_amazon.rc meta_init.connectivity.rc seapp_contexts
config init.aosp.rc init.mt8163_storage.rc meta_init.modem.rc selinux_version
d init.build.rc init.perfmonitord.rc meta_init.rc sepolicy
data init.common_svc.rc init.perfrecoveryd.rc mnt service_contexts
default.prop init.connectivity.rc init.project.rc multi_init.rc storage
dev init.environ.rc init.puffin.rc oem sys
etc init.fireos-post.rc init.randomseed.rc persist system
factory_init.connectivity.rc init.fireos-pre.rc init.rc postinstall ueventd.mt8163.rc
factory_init.rc init.fosflags.sh init.recovery.mt8163.rc proc ueventd.rc
file_contexts.bin init.ledcontroller.rc init.usb.configfs.rc property_contexts vendor
fstab.mt8163 init.modem.rc init.usb.rc root verity_key
1|biscuit_puffin:/ # ps
USER PID PPID VSIZE RSS WCHAN PC NAME
root 1 0 34008 2372 SyS_epoll_ 0008fe2c S /init
root 2 0 0 0 kthreadd 00000000 S kthreadd
root 3 2 0 0 smpboot_th 00000000 S ksoftirqd/0
root 4 2 0 0 worker_thr 00000000 S kworker/0:0
root 5 2 0 0 worker_thr 00000000 S kworker/0:0H
root 6 2 0 0 worker_thr 00000000 S kworker/u8:0
root 7 2 0 0 rcu_gp_kth 00000000 S rcu_preempt
root 8 2 0 0 rcu_gp_kth 00000000 S rcu_sched
root 9 2 0 0 rcu_gp_kth 00000000 S rcu_bh
root 10 2 0 0 smpboot_th 00000000 S migration/0
root 11 2 0 0 smpboot_th 00000000 S migration/1
root 12 2 0 0 smpboot_th 00000000 S ksoftirqd/1
root 13 2 0 0 worker_thr 00000000 S kworker/1:0
root 14 2 0 0 worker_thr 00000000 S kworker/1:0H
root 15 2 0 0 smpboot_th 00000000 S migration/2
root 16 2 0 0 smpboot_th 00000000 S ksoftirqd/2
root 17 2 0 0 worker_thr 00000000 S kworker/2:0
root 18 2 0 0 worker_thr 00000000 S kworker/2:0H
root 19 2 0 0 smpboot_th 00000000 S migration/3
root 20 2 0 0 smpboot_th 00000000 S ksoftirqd/3
root 21 2 0 0 worker_thr 00000000 S kworker/3:0
root 22 2 0 0 worker_thr 00000000 S kworker/3:0H
root 23 2 0 0 rescuer_th 00000000 S khelper
root 24 2 0 0 rescuer_th 00000000 S perf
root 25 2 0 0 down 00000000 D GCPU
root 26 2 0 0 update_cou 00000000 S update_tz_count
root 27 2 0 0 rescuer_th 00000000 S writeback
root 28 2 0 0 ksm_scan_t 00000000 S ksmd
root 29 2 0 0 ksm_seeker 00000000 S ksmd_seeker
root 30 2 0 0 rescuer_th 00000000 S crypto
root 31 2 0 0 rescuer_th 00000000 S bioset
root 32 2 0 0 rescuer_th 00000000 S kblockd
root 33 2 0 0 worker_thr 00000000 S kworker/0:1
root 34 2 0 0 rescuer_th 00000000 S md
root 35 2 0 0 worker_thr 00000000 S kworker/1:1
root 36 2 0 0 rescuer_th 00000000 S cfg80211
root 37 2 0 0 cpufreq_in 00000000 S cfinteractive
root 45 2 0 0 kswapd 00000000 S kswapd0
root 46 2 0 0 fsnotify_m 00000000 S fsnotify_mark
root 73 2 0 0 irq_thread 00000000 S irq/108-mt6323-
root 74 2 0 0 _hps_task_ 00000000 D hps_main
root 75 2 0 0 kthread 00000000 D mt_gpufreq_inpu
root 76 2 0 0 rescuer_th 00000000 S accdet_eint
root 77 2 0 0 btif_rx_th 00000000 S btif_rxd
root 78 2 0 0 ktp_thread 00000000 S kthermp
root 79 2 0 0 rescuer_th 00000000 S emi_mpu
root 80 2 0 0 kthread_wo 00000000 S spi32766
root 81 2 0 0 worker_thr 00000000 S kworker/u8:1
root 84 2 0 0 rescuer_th 00000000 S uether
root 85 2 0 0 rescuer_th 00000000 S uether_rx1
root 116 2 0 0 rescuer_th 00000000 S dm_bufio_cache
root 118 2 0 0 rescuer_th 00000000 S binder
root 119 2 0 0 worker_thr 00000000 S kworker/u8:2
root 122 2 0 0 mmc_queue_ 00000000 S mmcqd/0
root 123 2 0 0 mmc_queue_ 00000000 S mmcqd/0boot0
root 124 2 0 0 mmc_queue_ 00000000 S mmcqd/0boot1
root 125 2 0 0 mmc_queue_ 00000000 S mmcqd/0rpmb
root 126 2 0 0 worker_thr 00000000 S kworker/2:1
root 127 2 0 0 worker_thr 00000000 S kworker/u8:3
root 128 2 0 0 rescuer_th 00000000 S ipv6_addrconf
root 141 2 0 0 rescuer_th 00000000 S deferwq
root 142 2 0 0 down_inter 00000000 S entropy_thread
root 143 2 0 0 dboost_dvf 00000000 D dynamic_boost
root 144 2 0 0 rescuer_th 00000000 S f_mtp
root 145 2 0 0 sleep_thre 00000000 S file-storage
root 146 2 0 0 rescuer_th 00000000 S mt-wdk
root 147 2 0 0 msleep_int 00000000 S wdtk-0
root 148 2 0 0 msleep_int 00000000 S wdtk-1
root 149 2 0 0 msleep_int 00000000 S wdtk-2
root 150 2 0 0 msleep_int 00000000 S wdtk-3
root 151 2 0 0 ptp_volt_t 00000000 S PTP_CTRL_MCUSYS
root 152 2 0 0 rescuer_th 00000000 S kdmflush
root 153 2 0 0 rescuer_th 00000000 S bioset
root 154 2 0 0 worker_thr 00000000 S kworker/0:1H
root 155 2 0 0 worker_thr 00000000 S kworker/2:1H
root 156 2 0 0 kjournald2 00000000 S jbd2/dm-0-8
root 157 2 0 0 rescuer_th 00000000 S ext4-rsv-conver
root 158 2 0 0 worker_thr 00000000 S kworker/1:1H
root 159 2 0 0 __spi_sync 00000000 D kworker/3:1H
root 160 2 0 0 worker_thr 00000000 S kworker/3:1
root 161 1 11348 1588 0 0003c05e R /sbin/ueventd
root 166 2 0 0 kjournald2 00000000 S jbd2/mmcblk0p16
root 167 2 0 0 rescuer_th 00000000 S ext4-rsv-conver
root 171 2 0 0 kjournald2 00000000 S jbd2/mmcblk0p15
root 172 2 0 0 rescuer_th 00000000 S ext4-rsv-conver
logd 176 1 33468 5688 sigsuspend b695e110 S /system/bin/logd
root 182 2 0 0 kauditd_th 00000000 S kauditd
pwrsvcd 186 1 32264 5412 poll_sched b618200c S /system/bin/pwrsvcd
root 187 1 13564 1648 __skb_recv b6c76d28 S /system/bin/debuggerd
root 188 1 20052 3324 hrtimer_na b6b6cdf0 S /system/bin/vold
root 190 187 13180 456 __skb_recv b6c77f5c S debuggerd:signaller
root 195 1 13544 1384 __skb_recv b6de8d28 S /vendor/bin/kisd
system 196 1 11920 1092 down_inter b6e20f0c S /vendor/bin/rpmb_svc
ace_messaging 204 1 36104 4692 futex_wait b6cf8a68 S /system/bin/ace_messaging_service
system 206 1 47308 5996 futex_wait b64e2a68 S /system/bin/logmgr
ledcontroller 207 1 49548 7596 sigsuspend b64af110 S /system/bin/ledcontroller
system 217 1 12032 1088 poll_sched b6e4dfb4 S /vendor/bin/wmt_launcher
keystore 218 1 16668 3532 binder_thr b6c55f0c S /system/bin/fireos-dha
ace_eventmgr 221 1 19680 2104 futex_wait b6deba68 S /system/bin/ace_eventmgr
ace_otad 222 1 38644 4948 futex_wait b633ca68 S /system/bin/ace_otad
system 223 1 12960 1608 binder_thr b6c19f0c S /system/bin/servicemanager
root 228 2 0 0 osal_wait_ 00000000 S mtk_stp_psm
root 230 2 0 0 osal_wait_ 00000000 S mtk_stp_btm
root 235 2 0 0 osal_threa 00000000 S mtk_wmtd
system 236 1 15556 1656 binder_thr b6c59f0c S /system/bin/shmd
system 240 1 11624 1296 poll_sched b6e4e00c S /system/bin/sh
ace_sensorsd 241 1 27660 2412 futex_wait b6ac4a68 S /system/bin/ace_sensorsd
system 242 1 34236 2960 futex_wait b6aeda68 S /system/bin/ace_usagestat_protod
system 243 1 31596 3464 futex_wait b6be9a68 S /system/bin/aceusagestatd
shell 245 1 11624 1296 n_tty_read b6e85f5c S /system/bin/sh
root 246 1 77696 1896 poll_sched 0006bfd8 R /sbin/adbd
system 277 1 56440 8532 futex_wait b5e19a68 S /system/bin/UdssCampD
ace_tokend 279 1 34680 3948 hrtimer_na b6bdabb0 S /system/bin/tokend
ace_button_mgr 280 1 42684 6828 futex_wait b6a20a68 S /system/bin/acebuttond
ace_thermald 281 1 29476 2528 futex_wait b6b90a68 S /system/bin/ace_thermald
system 282 1 28728 3716 futex_wait b6640a68 S /system/bin/ace_metric_daemon
bluetooth 286 1 26248 3292 futex_wait b6855a68 S /system/bin/ace_coex_metric
ama 287 1 35056 4704 futex_wait b6269a68 S /system/bin/amakit_server
blemesh 288 1 74408 4100 futex_wait b6399a68 S /system/bin/ace_blemesh_service
ace_input_mgr 294 1 31288 5140 futex_wait b5e9aa68 S /system/bin/aceinputmanager
system 295 1 40728 5956 futex_wait b63cda68 S /system/bin/minerva_service
dbus 385 1 13260 2196 poll_sched b6db7fb4 S /system/bin/dbus-daemon
audio 386 1 75560 15984 do_sigtime b5cd7134 S /system/bin/mixer
audio 387 1 19056 3360 sigsuspend b6b46110 S /system/bin/BTSinkPlayer
ace_otad 388 1 53596 7136 do_sigtime b661b134 S /system/bin/otad
system 389 1 35476 6448 poll_sched b62f100c S /system/bin/perfmonitord
system 391 1 33140 5780 poll_sched b652f00c S /system/bin/perfrecoveryd
system 392 1 29724 4164 futex_wait b68b5a68 S /system/bin/acedropboxd
ahe 393 1 11624 1340 sigsuspend b6d54110 S /system/bin/sh
adepd 394 1 27984 6112 hrtimer_na b695adf0 S /system/bin/adepd
wifi 395 1 21596 2416 hrtimer_na b6c5cdf0 S /system/bin/netmgrd
trackerd 396 1 53936 8268 sigsuspend b657d110 S /system/bin/trackerd
uxevent 397 1 89356 15700 futex_wait b59d1a68 S /system/bin/uxeventd
keystore 399 1 15620 2596 binder_thr b6d7ff0c S /system/bin/keystore
ahe_shs 400 1 11624 1296 sigsuspend b6e74110 S /system/bin/sh
media 401 1 12640 1256 poll_sched b6d7a00c S /vendor/bin/securetime
wifi 402 1 33088 5764 futex_wait b689ba68 S /system/bin/sntp
wifi 403 1 49956 5056 futex_wait b6c5ca68 S /system/bin/wifisvc
factory_reset 404 1 66948 11732 futex_wait b4e5ea68 S /system/bin/factory-reset
provisionerd 405 1 62412 7872 futex_wait b629aa68 S /system/bin/provisionerd
ace_powerd 422 1 44608 3864 futex_wait b6a66a68 S /system/bin/ace_powerd
system 423 1 16524 1940 poll_sched b6dcafb4 S /vendor/bin/psbroker
ahe_shs 424 400 69248 16580 futex_wait b6ccaa68 S /system/bin/SkillContainer
ahe 426 393 108932 16668 futex_wait b6386a68 S /system/bin/AlexaHybridExecutionControllerLitespeed
system 440 1 18676 3488 SyS_epoll_ b6a7cdc8 S /vendor/bin/halo_bssid_scan
davs 593 1 55044 8260 futex_wait b6510a68 S /system/bin/assetmgrd
root 619 2 0 0 worker_thr 00000000 S kworker/0:2
root 821 1 12896 1812 poll_sched b6ce0fb4 S avahi-daemon: running [linux.local]
bluetooth 822 1 76036 8984 futex_wait b6338a68 S /system/bin/btmanagerd
commsd 828 1 56868 10412 futex_wait b673ba68 S /system/bin/commsd
puffinmrm 895 1 151232 22500 futex_wait b482aa68 S /system/bin/puffinmrmd
puffin 904 1 263428 40692 futex_wait b1e1ca68 S /system/bin/PuffinApp
dacd 910 1 44600 6488 futex_wait b5e26a68 S /system/bin/dacd
smarthome 911 1 137668 27188 futex_wait b58d6a68 S /system/bin/SmartHomed
root 1030 1 19904 1712 binder_thr b6d98f0c S /system/bin/neo-service-coordinator
root 1031 1 15048 2096 binder_thr b6d23f0c S /system/bin/neo-init
ace_dioded 1376 1031 40184 6164 binder_thr b6d23f0c S com.amazon.diode.neo
root 1653 2 0 0 rescuer_th 00000000 S amznspi
root 1654 2 0 0 rescuer_th 00000000 S audio_overrun_m
root 1676 2 0 0 worker_thr 00000000 S kworker/u8:4
root 1678 2 0 0 worker_thr 00000000 S kworker/3:2H
root 1716 2 0 0 tx_thread 00000000 S tx_thread
wifi 1729 1 21768 4492 poll_sched b6b5900c S /system/bin/wpa_supplicant
root 1731 2 0 0 worker_thr 00000000 S kworker/2:2
oobe 1837 1 74308 10624 futex_wait b6235a68 S /system/bin/oobed
nobody 1925 1 12004 720 poll_sched b6d2900c S /system/bin/dnsmasq
factory_reset 2005 1031 62580 11160 binder_thr b6d23f0c S com.amazon.factory_reset.neo
root 2116 246 11624 1360 sigsuspend b6d93110 S /system/bin/sh
root 2184 2116 12612 1364 0 b6d58f5c R ps
Looks quite straight forward. I’m a bit gutted I’ve no 2nd gen Echos now.
19:33:30.631948 IP 10.0.0.97.47164 > 10.0.0.254.123: NTPv4, Client, length 48
19:33:30.632370 IP 10.0.0.254.123 > 10.0.0.97.47164: NTPv4, Server, length 48
19:33:31.807313 IP 10.0.0.171.8770 > 10.0.0.97.44582: Flags [P.], seq 4767:4816, ack 4069, win 71, options [nop,nop,TS val 3921538179 ecr 4294904876], length 49
19:33:31.808880 IP 10.0.0.97.44582 > 10.0.0.171.8770: Flags [P.], seq 4069:4133, ack 4816, win 773, options [nop,nop,TS
val 4294906126 ecr 3921538179], length 64
19:33:31.809092 IP 10.0.0.171.8770 > 10.0.0.97.44582: Flags [.], ack 4133, win 71, options [nop,nop,TS val 3921538181 ecr 4294906126], length 0
19:33:31.809482 IP 10.0.0.97.44582 > 10.0.0.171.8770: Flags [P.], seq 4133:4910, ack 4816, win 773, options [nop,nop,TS
val 4294906126 ecr 3921538179], length 777
19:33:31.809693 IP 10.0.0.171.8770 > 10.0.0.97.44582: Flags [.], ack 4910, win 71, options [nop,nop,TS val 3921538181 ecr 4294906126], length 0
I've just picked up a couple of 2nd gen Dots to give this a go too, have missed having a voice assistant since ditching Alexa/Google Home.
"Hey Jarvis, turn on the immersion heater"
Yeh well worth it mate. For me it works surprisingly well
Apparently the echo show can be rooted too but not worth it imho
Also have fire hd ... that might be my next mini project
So long as I can strip off anything that would make it dial back to Daddy Bezos, I'm happy![]()
Bluetooth
DeviceControllerScopeFleetDevice
Turns the device into a Home Assistant Bluetooth proxy: it passively listens for BLE advertisements (presence beacons, temperature sensors) and forwards them to HA as a separate ESPHome device — independent of the voice assistant. Enabling permanently switches the Dot's Bluetooth chip away from Android's stack (Bluetooth speaker pairing, never used by EchoMuse, stops being possible).
