If your JUST playing steam games in big picture mode with odd web browserI'll be doing my installation later this week. I'm a bit unsure of the variants eg steamOS, CachyOS and Bazzite. Obviously steamOS is what's on the decks and machine but the other two have me unsure.
Thanks! Gives me some things to think over then before I get the final parts together then.If your JUST playing steam games in big picture mode with odd web browser
SteamOS - super stable slower updates of arch Linux maybe updates once or twice a month
if your wanting to consider playing games from epic, gog, battlenet
It be easier on Bazzite not impossible on steamOS but you’d need desktop mode to install those apps
Bazzite runs on fedora linux, it’s faster package updates than SteamOS maybe once a week generally stable but still early
If you want a standard desktop machine that you can do anything on including gaming CachyOS is possible option
Cachyos is super bleeding edge you have Linux package updates every few hours
Daily you’ll seee at least 5 updates
However packages are so new there basically just been releases of the dev pc available to download
CachyOS dies protect you by doing snapshots on updates which are tiny 12kbs for some of mine
I’ve been running cachyOS 4 weeks? I’ve killed boot up once as I updated my system when only half of the GUI packages were released to download
Snapshot fixed that, and updating 1 hour late was fine again
Pretty much what I didThanks! Gives me some things to think over then before I get the final parts together then.
I might even just give them all a try and see which one works better for me I suppose.
It will mainly be used for TV gaming. I've got my desktop PC for desk gaming etc. This is for more of a lounge and chill unit some of the time. Perhaps I shall give SteamOS a try first then maybe try Bazzite. I could possibly look at a dual boot between the two and flip between the two and decide from that.Pretty much what I did
I used SteamOS and loved it, but found myself wanting to use discord and OBS which requires desktop mode because vavle in there wisdom doesn’t allow steam broadcast on Linux yet.. even though it works
So I think as using desktop 90% of time and some apps required OS tweaks which STEAMOS doesn’t allow as OS parts are read-only
So I jumped right to Cachy as I knew a desktop was required
If your using a TV experience I would use steam or Bazzite
If you going down desk route + gaming I’d go down cachyOS Or more stable Linux desktop distribution
I’d go with bazzite as it has support for non steam launchers out of the boxLooking at a couch gaming setup for myself. I want to play my steam, blizzard, GOG games. It will be an AMD build and I guess from installing the games in desktop mode it'll be 99% console mode just using a controller.
Steam or bazzite?
No handle but Lian li a3 is not to bad fits biggest GPUs if needed tooI've been fiddling away the past week or two building this in my spare time:
Ryzen 7 7700 £110
B850M MSI Mortar £145 (I could have went cheaper but wanted better VRM's for potentially dropping in later CPU's)
DDR5 SK Hynix Greens (OC to 6000 C28) £109
1000W MSI A1000GLS PSU £85
SF1000 - £110
2x2TB Drives pulled from my laptop that I am selling and no other purpose for currently.
Acer Nitro 9070 OC £260
I've triple booted it due to trying to dabble in GPU repairs. Windows and Linux for stress testing software, diagnostics etc and then steam OS.
I've called it the steam bench.
Although looking for a compact case with a handle that I can then use it between locations rather than an open air bench now.
That's on the shortlist. Another member has a ch160 plus which fits everything fine with a bigger GPU so I'm tempted with that.No handle but Lian li a3 is not to bad fits biggest GPUs if needed too
Thanks smogsy, seen your case that's the one I want as well. I'm looking at a SFX PSU as that will give me more room for a bigger GPU and an aio to try and keep it quiet in the lounge.I’d go with bazzite as it has support for non steam launchers out of the box
No hacking required might even be able to do some setup with controller only
So I went with seasonic gx core 850w it’s standard atx and is short so it can have 9070xt with no issues. The osu is not loud but louder than everything part from GPU idle this in a slient room soon as tv is on cannot hear itThanks smogsy, seen your case that's the one I want as well. I'm looking at a SFX PSU as that will give me more room for a bigger GPU and an aio to try and keep it quiet in the lounge.
