Steam Machine (OS) Build
I'll be doing my installation later this week. I'm a bit unsure of the variants eg steamOS, CachyOS and Bazzite. Obviously steamOS is what's on the decks and machine but the other two have me unsure.
If your JUST playing steam games in big picture mode with odd web browser
SteamOS - super stable slower updates of arch Linux maybe updates once or twice a month
if your wanting to consider playing games from epic, gog, battlenet
It be easier on Bazzite not impossible on steamOS but you’d need desktop mode to install those apps
Bazzite runs on fedora linux, it’s faster package updates than SteamOS maybe once a week generally stable but still early
If you want a standard desktop machine that you can do anything on including gaming CachyOS is possible option
Cachyos is super bleeding edge you have Linux package updates every few hours
Daily you’ll seee at least 5 updates
However packages are so new there basically just been releases of the dev pc available to download
CachyOS dies protect you by doing snapshots on updates which are tiny 12kbs for some of mine
I’ve been running cachyOS 4 weeks? I’ve killed boot up once as I updated my system when only half of the GUI packages were released to download
Snapshot fixed that, and updating 1 hour late was fine again
Thanks! Gives me some things to think over then before I get the final parts together then.
I might even just give them all a try and see which one works better for me I suppose.
Pretty much what I did
I used SteamOS and loved it, but found myself wanting to use discord and OBS which requires desktop mode because vavle in there wisdom doesn’t allow steam broadcast on Linux yet.. even though it works
So I think as using desktop 90% of time and some apps required OS tweaks which STEAMOS doesn’t allow as OS parts are read-only
So I jumped right to Cachy as I knew a desktop was required
If your using a TV experience I would use steam or Bazzite
If you going down desk route + gaming I’d go down cachyOS Or more stable Linux desktop distribution
It will mainly be used for TV gaming. I've got my desktop PC for desk gaming etc. This is for more of a lounge and chill unit some of the time. Perhaps I shall give SteamOS a try first then maybe try Bazzite. I could possibly look at a dual boot between the two and flip between the two and decide from that.
