Guys,
No one else is helping me but which P35 motherboard is best for a q6600 G0
Gigabyte , Asus or Abit?
Ip-35 pro looks good but its very expensive, Anything wrong with a p5k or a Ds3P?
sid
got the abit p35 pro here and all is well so far
I went through 4 motherboards on my 939 setup in 2 years, bloody ridiculous tbh.
I really want something uber stable,
How far do you think this setup will go?
Q6600 G0, Ip-35 pro, Arctic Freezer 7 pto, 4gb OCZ pc6400 rev2
Any chance of 3.5ghz?
sid
would have thought so.
I had it looping 3D mark 06 over night, done rendering work and played Bioshock all at 3.8GHz. To me it's stable, because it does everything i want with no problems. But i'll prime it over night just to shut you lot up![]()
No, an Asus Blitz is very expensive. The Ip-35 Pro is a great board for quads, I've had a couple of the top end P35 boards and the Pro needed less vcore than the others.
Btw, older cpu-z versions report incorrect vcore values. Try 1.40.8 onwards.
I'm sure he said p5k not blitz.....![]()
, even with the memory at 1:1 (DDR2-860) I can't seem to get stable!
Just got mine today guys, G0 stepping
An hour ago whacked it on to 400x8 at stock volts, on an Asus Blitz Formula, played some bioshock and stalker, seems ok so far, will run prime overnight though
But chances of it being stable on stock volts at 3.2?
TTIUWP!
Come on guys gives us some Prime screenshots or at least some PI runs and don't forget the week codes.
Mines L726A977
Is that set in bios, uguru or actual? There's a hell of a droop+drop on that board.stable here so far at 3.6ghz 1.5v (will tweak this later) temps full load using core temp are nice at 55c small fft prime![]()
