6 hr+ prime shot for stability?Yep, well i was playing Bioshock for an hour at that speed and it was fine... gone down to 3.8GHz now though 'cause my RAM needs too much voltage at 3.9 to run at over 850MHz and i dont wonna kill 8GB.
3.9...
I'm not sticking my 8GB RAM on 2.25v for 6+ hours of prime, it's too risky. But i have some cheap OZC RAM and i'll prime it using that over night.
I honestly think i could get 4GHz stable if i had some quality fast RAM.
Im thinking that i have got a bad clocking chip, needs 1.5v in bios to be stable at 3.4. What is the maximum voltage i should be looking at?, bearing in mind that it only just hits 60C under water at this point.
When people quote voltages, are these in bios or cpuz? because at idle my vcore droops by 0.05v and anything up to 0.125v under load, is this normal?
Alex
A system should be built to use, either it's stable and usable 24/7 or it's not.
If it's too risky, then stop overclocking and go back to stock.
I take it that it is not stable at all and is thus rather unusable.
i've got it stable at 3.8 now on 1.5v
Your volts look very low1.150 v, I thought default was 1.280v?
Forgive me
Have you posted a stabilty shot at 3.8ghz?
What batch is that one ?
In my excitement i forgot to write down before i put it in, i aquired it from OcUk only a few days ago.
Alex
Alex
Easyrider, did yours come today?
It will say on the box.![]()
I had it looping 3D mark 06 over night, done rendering work and played Bioshock all at 3.8GHz. To me it's stable, because it does everything i want with no problems. But i'll prime it over night just to shut you lot up![]()
