That looks knackered, rear suspension is clearly broken. There's plenty out there that will be better.
Owned one for 7 years and did over 100k in it (1.8 Type-S GT, 160k miles in the end). I had two major issues, front shocks died (cheap enough job) and the gearbox input shaft failed (replaced with low milage used). Gearbox was likely my fault, car had an incredibly hard life and they're not a known issue.
Avoid Diesel aside from the 2.2, make sure it's had a clutch and dmf done in its life. Petrol you want the 1.8, they are absolutely bomb proof.
If you like ride quality avoid 18" wheels, plus the tyres are expensive. You should get a decent average miles EX/ES/Type-S GT for similar money I'm sure.
I didn't maintain mine cosmetically and it had hidden crash damage from a previous owner but I had zero rust.
