Yup tried about 8 times.Have you tried doing the bios flashback several times?
Yup flashes 3 times then flashes for a good 4-6 mins.Is the MB reacting properly, light flashing and then going out?
Are you doing the flashback with no other components connected to the MB?
I’m using a Corsair 850x but have tried with a rog 1000w as well.What PSU are you using?
Have you ruled out a faulty 14900k?
Well my 12700k doesn’t boot in it either so I can’t only think it’s the board. I might ask OCUK about swapping it or something, see what they say.Have you ruled out a faulty 14900k?
cpu temperature as 81C but if you expand it to see the individual core temps, 6 of them are at aroun
I read all the posts, so I gather it's the BIOS update you tried that might be the issue, if so not a lot you can do apart from usual ie reflashing, take CMOS battery out etc , however if the board is dead due to BIOS update then only solution will be a new board.
You need to get the motherboard checked by a third party to make sure it's dead then go on from there.
Think I would be tempted to get a new motherboard to try.
I have the same motherboard and I went from a 12700k to a 14900k.
Before I put the 14900k in I updated to the latest bios and reset the bios to stock settings then put the 14900k in and luckily it worked.
From the pic it looks like you only have 1 of the cpu power connectors in? If you haven’t got both connectors plugged in try that?
The extra 8 pin isn’t needed, only when overclocking.I looked at your pic and had a looked at user manual, it appeared in the pic you plugged 2 ATX power connectors to A: ATX_12V_1 and C: ATX_12V_PWR so it seemed you forget to plugged in 3rd power connector to B: ATX_12V_2. You will need to plug in three power connectors to ports marked A, B and C accorded to manual motherboard diagram.
Damn, that it seems you now have to deal with a dead system and you have 14900k that still can't be tested. Guessing that also has a limited easy window of returns. What will you do about the 14900k...?
Considering you can't boot, worth trying with both connected. Perhaps the new BIOS update made it require both cables to be connected? Won't cost you anything to tryThe extra 8 pin isn’t needed, only when overclocking.
I think the only option is to rma the motherboard and see what they say. I did purchase it in 2021 tho, hopefully they can sort something out (not OCUK). I’ve got a z790 coming tomorrow so I can at least test the cpus and go from there, will try the 12700k first.
