Gareth, the best advice I can give is don't skimp on the PSU. get a quality one. Unfortunately, with PSU's, a higher price usually means it's better. Looking at your rig, I would certainly recomment the Corsair HX520. It is within your £72 budget if you shop around.
Trust I've heard of, make nice cheap products, PSU's however...I wouldn't get from them, Sumvision I've never heard of.
Makes of PSU I have heard of Enermax, Antec, Corsair, Seasonic, Tagan, Akasa, Silverstone, etc.
For your rig, your looking at a minimum of a good quality 500watt PSU. The only way you've managed to get away with your Q-Tec PSU is either Q-Tec broke the mold when they made your particular PSU for whatever reason, or, and most likely, LUCK!!!.
If you put the HD2900Pro into your system with your current PSU, or one that isn't up to scratch, your computer won't work properly, it will become unstable, and the PSU could very well end up exploding and taking out a few components with it.
