That audio looks quite good, the TXC Oscillator is to help with timings.
My gigabyte motherboards never had audio this quality.
Lucked out
like for like the slicks were better subs. definitely sounded better sealed. The drivers are buitl better as well, not generic baskets like the pulse range. Bigger magnets, better power handling. If anything, vibe have gone backwards. As difficult as that is to believe for what was already a budget brand.
At least a little interesting ...
Generic...
And yeah, still dont believe you. Considering the crap you've come out with in this thread already, i've no reason to believe anything else you say.
Oh dude just stopYou are missing an important part too, the Slick subs are rubber and made out of plastics, the Pulse sub is paper and very lightweight.
This subwoofer features our single piece technology cone made from IMPP for increased strength and rigidity and a clean tight bass response, this is tied in with our heritage VIBE styled brushed alloy effect surround.
Vibe were always known for tight bass, not exactly low bass which the Pulse manages.
The 2 full range speakers are paper also with inverted tweeters.
https://www.focal.com/en/car-audio/car-audio-kits-solutions/performance/auditor/coaxial-kits/rcx-130
TECHNOLOGY
The car audio kits in the Auditor line feature high-end technology: they still have a 1" (25mm) voice coil on a kapton frame, a powerful 31/3" (85mm) magnet, a matt black polypropylene cone and butyl suspension...but the new feature for 2017 is our famous inverted dome tweeter, a key representative of Focal’s core values. The Mylar used for the dome allows for a combination of extremely low mass, minimal directivity and excellent linearity in the high end, something which is unprecedented in this price range
27hz? My main speakers go down to 27hz, don't mind about the sub. You sure we're talking about the same subject?
My Kef's HTS2001's have a range of 80Hz - 27 kHz. I'm going to be straight up controversial here but I played the recorded vids back to back against what mine reproduce in the same songs outside of youtube via spotify premium, trying to also account for youtube compression, quality of MIC etc etc etc... I recon 2 of my eggs alone give a cleaner sound than the video above especially in the mid notes, I dunno what it is but when I replay the ops vids I just get this mass of sound in the midrange that just isn't there this end outside of the ops vid. I think I will just have to assume that the way the op is recording is very much less than optimal otherwise I have to just assume it sounds pap which is not what the op is describing
I'm not even joking I spent about 30 mins playing "take my breath away" back to back.... Im really sorry op but tell me im wrong:
Id be happy to be told im wrong and why, even tell me im missing the lows but honestly at this point im onboard with going to get my sub out from under the stairs and seeing what it sounds like connected up and if it fills the mids out like in the ops video. Alternatively tell me what I already know and that a youtube (compressed) recording from a phone playing an already compressed youtube video is a shocking idea. I wanted to turn it up and be blown away but the opposite happened.
Its mostly this.
A comparison, this channel does a reasonably decent job at comparing speakers in a more controlled manner:
Works best with headphones, and the format only works because it it gives a comparison between two relatively comparable speakers, and the reference track.
I said use good headphones because most people don;t have speakers than will go even below 50hz let alone near 30.
'Doesn't matter to me it actually sounds even worse in my soundmagic e80c's.... so much "sound" in the mid that just shouldn't be there/isnt there on my setup. I'll pull my mission sub from under the stairs and re-do it if you want? I promise though that will just make it sound worse still I recon.
I hear you, your speakers at the desktop pretty much resemble closely how my Presonus Eris's sound, accurate precise audio.
I will have a mess around later and get my AVR receiver out and do a test on the mid range without the sub woofer and see if I can get anything more out of those two speakers, I do have some Denon I can switch up with and see how they play.
So its going to look something like this with the big Jamo under the table ... hoping for a big improvement over crappy little logitech 2.1 system. The Missions are over 20 years old now but always liked them. Rear port so will have to bung up as against wall?
