3090 Reported To Be A Laughable 10% Faster Than 3080
yes, because I'm sure they'll bring out the 20gb version for £700..
£850 is the leaked price for the 3080 20Gb so the extra 10Gb is costing you £200 so around £20 per GB.
On that basis a 24Gb 3080 would cost £930. Obviously there are more cores/shaders etc on the 3090 but you are paying £500 for those, not the memory.
I don't think there will be a 20gb 3080 to be honest . I would wager that to be the 3080ti that will be coming out next year, although if the 3090 is only 10% faster ... how it would look performance wise is baffling.
Wont be the first time they have done that. I bought a titan Xp and then a few months later they launched the 1080ti and it was 96% of the performance of the titan, just less memory. Since AIB versions had better cooling and power and overclocks, some 1080ti were faster.
If they need to in order to compete with AMD, they will launch one that makes the 3090 a total waste of money.
Dude on reddit seems to have a 3090 already, seems legit. https://www.reddit.com/r/nvidia/comments/ix9zcg/early_msi_geforce_rtx_3090_gaming_x_trio/
He's quoted with the following performance:
Time Spy (graphics): 20569
Time Spy Extreme (graphics): 10560
Assassin's Creed Odyssey (4K/Maxed): 71
Horizon Zero Dawn (4K/Ultimate Quality): 86
Red Dead Redemption II (4K/Maxed/No MSAA): 66
Shadow of the Tomb Raider (4K/Maxed/DLSS/No RT): 112
Shadow of the Tomb Raider (4K/Maxed/DLSS/RT): 82
Control DLSS Quality 55-70
Control DLSS Performance 80-95
Obviously not like for like specs vs other reviewers for the rest of the PC but seems 15-20% better than 3080 perhaps.
Unless you compare both a 3080 and 3090 on the same/a similar rig it is not going to be comparable, his CPU is good enough for 1440p and 4k results but he seems to get higher score on 1080p than 1440p which it should not, some claim his RAM is holding it back.
He did at least provide pretty good proof he has the card.
