well i have a x570 MSI latest bios 1.b0 and latest patch c
with my godlike motherboard and 3950x i do not have this optimizer menu i think its a 5xxxx series option that unlocks once you still one of those in lol
AMD goodies coming and will trickle down to all.
Some links from AMD if anyone wants to read.
Beyond AGESA 1.1.0.0 for Ryzen 5000 Series:
Returning support for negative core voltage offsets (“undervolting”) with all-new AMD functionality for better frequency, voltage, and performance tweaking
Additional AMD optimization for performance and stability at ~2000MHz fabric clock. While not all processors are innately capable of reaching this frequency, our tuning is intended to help stabilize the overclock on capable samples2 —good luck!
Additional functionality tuning for benchmarking under extreme OC conditions (e.g. LN2)
[/URL]
Robert Hallock twitter
1) Ryzen 5000 Series doesn't need a power plan. Don't expect to see one.
2) Yes, it can clock to DDR4-4000 1:1 if you have a good sample. Upcoming AGESA work will make this easier.
3) But you CAN tweak Ryzen perf vs. power with the Win10 Power & Sleep sider AFTER you install the chipset driver.
4) Is the memory controller the same? YES.
5) Do you need a new AGESA for pre-5000 Series CPUs? No. Not really. Stay on the BIOS you have.
6) But ROBERT what about the VOLTS and the CELSIUSES. WHAT IS NORMAL?!?!!?! ROB HELP. See below.
[/URL]
7) What is the best memory to buy? TOUGH QUESTION
8) I see this a lot: "precision boost is automatic overclocking." No. False. Wrong. Precision Boost is our boost technology. Every processor has a boost technology. But ours is unique in that X THREADS do not equal Y CLOCKS. Why? Because that is SLOW.
[/URL]
9) But Robert, where is undervolting? Answer: IT'S GONE. j/k. Temporarily gone for 5000 series. It'll be back in an upcoming AGESA with new functionality.It's gonna be HYPE. Y'aint never seen undervolting quite like this.
I do not have a Aurous Master so I can not say.Read post #62 and ask manufactureCan you do this on aurous master yet ?
What monitoring tool do people use im seeing a huge difference in reported frequency between ryzen master (showing max 4.6ghz single) and hwinfo (showing 4.95ghz single)
That is awesome and only get better on new agesa, for CPU's I may have a solution for you as it may apply here. I only notice this way more when I switched RTX 2080 ->RTX 3080
Fan setup
Top Mount
CPU - 78.5°C
Chipset - 56.5°C
GPU - 58°C
Front Mount
CPU - 63.3°C Dropped 15°C
Chipset - 59.5°C Raised 3°C
GPU - 60°C Raised 2°C
https://forums.overclockers.co.uk/t...nt-to-front-rad-mount-with-rtx-3080.18902244/
Yeah just a thought ,me on the other hand I do not care what my case looks like. It is not even in the same room attached to 2 of my 4K monitors lol.
Ghetto all the way for me.I switch the rad from vertical to horizontal with bracket I made,so I do not have to refill the AIO after awhile.
What stock voltage and offsets in curve did you use to get above 5ghz?This worked an absolute treat on my 5900X
It is an AMD feature, now what I can not tell you all the motherboards that have it. You have to check AMD list of motherboards. It just may be AMD does not want it released yet on every motherboard but there are different links in this thread that have different motherboards listed.
Set CPU up to 5000Mhz and I see a lot of 5000Mhz but I did set locked 60FPS
AMD 5800X 5000Mhz RTX 3080 4K HDR 60 FPS Assassin's Creed Valhalla
@Vogon
Just spreading the love
Full Cinebench20 Run for those interested
Single core 652
Multi Score - 6136
Idle temperatures- 29°C
Full AVX load -77°C
All Motherboards except MSI are limited to 200Mhz,want to go higher use the new ASUS tool released ASUS DOS OverclockingCant go above 200mhz on asus crosshair hero
I used a 5800X,5600X boost is what out of the box 4750Mhz.@gerardfraser How did you set the cpu to 5000 by adding the nessary Offset i.e. +300/350 for 5600x. ??
