Really happy with my move from 5820k to 3600, power use is a big one, in that it is way lower. Performance is up a little bit, and can drop a 4950x into comp when they are out
I wouldn't be happy at all. You would have been much better off dropping a 5960x in the rig you had, rather than side-grading to then upgrade to a 4950x in a year's time
Err are you seriously suggesting that he should have put in an overpriced 6 year old CPU with a TDP of 140w and that has a boost clock of 3.5ghz? While also putting up with a hugely outdated platform? I had to go and have a look at some reviews and as far as I can see the 3600 is a decent little upgrade, better fps across the board, much better in productivity, better platform. I also had to go and look at pricing on the 5960x and on an auction site they are seemingly commanding more money than a new Ryzen. This seems like terrible advice unless you can pick up one of those CPU's for no money and are willing to overclock it but I just can't see it matching the cheaper Ryzen.
Still pretty much a sidegrade... If your going to "upgrade" at least buy a 8 core.
I picked up a 5969x for £200 about 18 months ago. Sold my 5930k for £140
So for the sake of a few quid it would save loads of messing and money. But whatever AMD FTW
I just can't imagine spending £200+ on a 6 year old CPU running DDR3, USB2 etc regardless if it is AMD or Intel. Surely there has to be better moves even on Intel?
lolz at 5960x
/QUOTE]
What does lolz mean? That a 12 year old thing?
A 5820k to a 5960x is a great and cheap upgrade lolz
Go back and check a few more reviews. Then when you have educated yourself, let's talk sense ?
Here is the page for ARC page for the cpu: https://ark.intel.com/content/www/u...extreme-edition-20m-cache-up-to-3-50-ghz.html
My bad I thought it was DDR3, either way it's still expensive, relatively slow out of the box, draws a load of power and actually isn't very fast even compared to entry level hardware today. If you genuinely think it's worth the £200+ it commands second hand then you crack on. I know where my money would be going and I wouldn't be putting it into a 5960x. It just seems like utter madness to me.
So the platform isn't much different from any other new platform, the power when overclocked (this is a overclocking forum after all) is pretty much the same. It would be a cheap upgrade and I don't care about 50p in electricity per year. ?
Lockdown getting to you? Making petty arguments ?
Can you back up the 50p electric difference claim?
That's a no then is itHook,line and sinker
I genuinely believe it is poor advice.
So staying, spend £80ish to get 2 more cores and minimal effort is poor advice, then what's yours? Because all I can see is a petty argument about it being ddr3, usb2 and slow out of the box :s oh and a bit more electricity
