Hmmm well i tried my 6 pin pci cables again using just 1 modular cable with the split 2 x 6pins and its worked now. Powered up first time but i had to wait awhile before turning the computer on as in wait a few mins. I didn't need to turn off the power supply and wait for motherboard light to go out. But i know for a fact if i reboot now it will not work.
I'm starting to think it maybe a voltage problem being delivered across the motherboard and memory? Maybe the psu isnt compatible with my setup hence why changing psu fixed it even if it was a less stable and cheaper psu.
Thats a shame mate, I was holding out hight hopes with that one. I would say its power supply related rather than any other hardware, I guess the best place to be with this is a PC shop that has all the spare components so they can swap them out one at a time and see where the issue lies.
It's horrible when this happens though and I feel for you even if it is a minor (ish) issue, as you say once it is going its a beast - Good luck at the shop mate and don't let them talk you into any costly work just for the sake of it.
This sounds like a similar problem I had on my old system which had an Creative X-Fi Gamer sound card. When I booted the computer from cold the sound card would work fine but if I had to reset/reboot the PC for a Windows update for example the sound card would cease to work the next time Windows had booted. However if I simply shutdown the PC rather then rebooted and booted again the sound card would work fine. So the situation was
Reboot – sound card wouldn’t work
Shut down – sound worked every time
It turned out the capacitors on either the PSU or more likely the sound card didn’t clear down properly from the reboot as a charge was still being held in them. You might want to try just shutting down your PC then booting it again rather then rebooting.
that way if it is faulty you can buy a new one right away and then rma the one with the problem, selling the replacement they send should cover most of the costs if you get a good price for itJay85, I see you have the same motherboard as me.
I have mate, have you ever had any problems with high end graphics cards and your board?
