Lots of people is saying 6th is meant as a cruising gear, but in my experience every car I have driven with a 6th (or 7th!) gear isn't really any taller in top gear than a car with a 5 speed box. The difference is more in the spacing of the ratios rather than them adding a mega tall ratio at the top.
Case in point... 7th gear in my M5 gives about the same rpm at a given speed as 6th gear in my old m5 and neither are particularly tall. If anything both could have done with an additional/taller top gear to help with cruising at motorway speeds.
I think in a manual 6 is about the ideal balance between frequency of gear changes and optimum performance.[TW]Fox;19874723 said:The ratios on the 6 speed box are just closer, which I am not sure is helpful given the power delivery of the engine.
Hehe well they are quite daggy at lower speeds. Mine isn't quite as refined as the newer one in the F10 but has very similar characteristics. At high speed or when you're gunning it the sound is quite foreign - not really like a petrol or a diesel. When mooching around town at low speed it's still very much a dagdag.Did somebody say diesels go "dagadagadaga"?![]()
70 MPH @ 1650 RPM ***6th gear to me means 70mph at 2100rpm and 50mpg from a 1.6 16v turbo lump pushing 211bhp.
Should get a car with 2 reverse gears, thats what the big boys do!
[TW]Fox;19875086 said:50mpg, lol keep thinking that. The instantaneous readout has a lot to answer for![]()
They're not all like that though.6 gears are great, closer ratios for 1-5 then overdrive in 6th for motorway.
Well this was over 8 miles, and I was in full Werthers, pipe and slippers mode
My car is just around 3500 rpm at 70mph.
/wants 6th gear.
As others have said, on lots of cars there just closer together and dont actually give you a "cruising" gear.
