my GTI-6 (slowest car in it's class!
) runs over 3,000rpm when doing 70. if anything I wish 6th was a bit longer that it currently is but leave all the other gears as they are! I have nearly put my mums Micra into reverse a few times.
As for when you should be in sixth gear I just run through the gears changing up when i can. you should always aim to be in a higher gear if you can.
) runs over 3,000rpm when doing 70. if anything I wish 6th was a bit longer that it currently is but leave all the other gears as they are! I have nearly put my mums Micra into reverse a few times.As for when you should be in sixth gear I just run through the gears changing up when i can. you should always aim to be in a higher gear if you can.
My car however only has 5.
My mower has 5 gears too.
My polo does 3000rpm at 70
