2700x has cheaper motherboards and doesn't require quad channel RAM to get the most from it.
Ahh, thanks.
not sure how they config the 1900X, if only one ryzen die of 8 core working + quad channel ram then it might potentially slightly faster than ryzen mainstream. But if there are 2 dies with 4 core each die and connected via IF then it's the worst, won't be faster than normal ryzen and inherits ton of latency.Hmmm.....I'll have to take a look at that. Fifty fps, as you say, is more than a 'bit'.
I'm hoping the 2920X will be at a tempting price, if not, then maybe the 1920 - 1950X's.
Is there any reason to get the 2700X over the 1900X? Apart from the cache and clock speeds, is there any real world difference? Quite a difference in price at the mo.
I would never buy the 1900x since its not worth it if you count the motherboard price and ram. TR platform is great for high core count, low core count => AM4 all the way.
1900x games quite nicely, 2xxx will be even better as the boost clocks will be higher and more cores will boost. Latency impact is not bad at all. I've never been left wanting for more game performance and mine is first gen which I don't even bother to overclock.
With respect, you are using a 480. A card that wasn't fast when it was released 2 years ago. An i3 could push that.
I have 2 1080Tis, it does OK, newer TRs will be faster still due to much better boost algorithms.
https://www.3dmark.com/compare/fs/16050392/fs/15537877
480 was a temp card to test build after offloading 3x 290x, its actually not a bad card, can mix with a 1060, still have it in another machine..
1440p 144hz or 4K 60hz (both gsync)@smogsy what resolution do you game at btw? as that has a huge impact on CPU utilisation, if your gaming 1440p or 4k then the CPU is less relevant as you know when gaming, as the GPU is bearing the brunt of the work, which means your CPU resources are much more able to be put to work on other more intensive bits.
Im guessing your either 1080p or 1440p though and not 4k.
The 9900k should not even be considered for you, at the minimum your going to want a 7900K or TR 2nd gen i reckon. No point swapping to another 8/16 chip that has better IPC, as your still going to be limited in your overall task set, if your already struggling on an 8/16.
Id look at the 7900 and TR 2nd Gen, then work out what kinda budget you need for both setups, if you have a set overall budget you can work out what savings on one will enable you to add on the other.
just wait for new intel chips.going the amd route will have you swapping again to the intel better set up. i already seen how you like to swap and change and gaming at the top end their in no comparison to intel.especially on high hz monitors.
some low end i5s beat top end amd stuff. nevermind higher end. or newer intels to come.
If I was doing a gaming build and a productivity build, it'd be 8600k gaming 2950x productivityalternatively if i went to 2 Builds, What would you do?
(also consider the gaming build would be 1080p 240hz)
