I downloaded afterburner extreme off a well known torrent site, didn't unlock any extra volts on my twin frozr 7950 though![]()
Already tried that, must be too old a version.
Scott B said:You are correct about EK, I sent them the sample a while ago and they have told me that they expect the blocks to be finished in the next few weeks.
Scott B said:With most GPU's, if you can keep it cold enough there is no upper limit, especially with 7970 were just a few degrees makes a difference even on air. A voltage that works great for one GPU will fry another.
Scott B said:With that in mind the unlocked limits available on the card are only recommended for LN2 cooling. In my experience as long as you overclock gradually you'll find the natural limit quite easily.
Scott B said:I'm afraid that Afterburner extreme is only made available to trusted extreme overclockers who have to sign a library load of forms before they get it.
Edit: Ran AB Extreme, won't read driver number, acknowledge that the card has 3D clocks or even monitor or adjust voltages. Probably something on my end so I'll give it a miss and try out 2.2.2
Edit2: I've also just noticed that GPUZ reports 1.170v, AB reports 1.174v and AB OSD reports 1.87v ?
I tthink perhaps you enter the info your self.
Going to try ln2 BIOS tomorrow to see if I can get this voltage to move. Latest gpu shark also only reads 1.170v
